What is the biggest tire I can put on a 22 inch rim Stock air suspension with Mangnaride 2023 Tahoe Z71.
GPZ71
In the market for new rims and tires, I think I will be going with Fuel 22” rims but not sure what the biggest tire I can go with without any rubbing issues. Please advise thank you!
KMeloney
Welcome to the forum. Someone may reply to your post with the answer you're looking for, but in the meantime, know that there are A LOT of posts about this already. Scroll through this and the General forum, and you'll find the info you're looking for.
if you use a leveling kit about the largest you can go without a bunch of modifications is a 305/45, may still rub a tiny bit at full lock or on the splash guards which can be trimmed or zip tied. stock height will be less
As @Doubeleive stated, a 305 width at the lower profile is about the widest you can go without rubbing. If you are looking for a taller sidewall, you'll have to sacrifice tire width.
Drewphil
