Pulling 4L65 fluid loss
project_x
Today I got around to pulling my LQ4 and 4L65E from the chassis of a Denali I picked up to part out for a few things.
The engine came out smoothly.
I removed the drive shafts from the transfer case.
Front of transmission resting on 2x4 across the torsion bars. I unbolted the trans mount.
Then I lifted the transmission and AWD transfer case.... Worrying about not dropping the transmission... I didn't think about the tilt and managed to dump the transfer case fluid all over the floor.
I then proceeded to unbolt the transfer case and lifted it to the ground. Using the engine hoist I lifted the transmission up to to clear the frame and get the frame out of the garage.
Somehow in this process I lost a lot of transmission fluid... But I wasn't paying attention to where it was leaving the transmission.
1. Cooling lines
2. Tail?
3. Torque converter?
Any other spots? This was a running transmission that had been rebuilt by reputable company 20k miles ago...
I think it was from the cooler lines mostly... Just don't want to miss a seal that has issues
strutaeng
Dallas, Texas
1. Cooling lines
2. Tail?
Yeah, probably from the cooler lines, and maybe a bit from the tail shaft (no trail housing since it's not a 2wd).
Did you remove the torque converter? If you didn't, then there shouldn't be any ATF spilling from it...
P
project_x
Thanks, I didn't remove the torque converter.
schafer98
