2013 chevy tahoe Z71 running boards
Landonz
I have a 13’ Z71 Tahoe and the plastic on top of the running boards is cracked and getting wore out in multiple spots. Does anyone know if you can replace just the plastic piece? If so where do you find replacements at? Or do have to replace the entire running board?
I don't know about the top but on my denali there is a chrome trim piece that can be replaced, there are 2 pieces on each running board and each piece is around $100
I replaced 1 and I was lucky enough to figure out how to replace it without breaking the 2nd piece as they overlap in one spot.
you might try just getting a replacement from a junkyard in the past I have had yards sell them for about $50 each
mikez71
I believe a member here @The Grey Beast found a replacement cover before.
And I thought he mentioned that one side fits either side?
I found the Z71 steps to be slippery and converted to stock running boards.
GlennSullivan
Westchester, NY and Jupiter FL
This looks like it might be the correct part for the passenger side (it looks like the top of my 2007 Z71 RB) (first link and pic) and is available for special order.
The drivers side (second link and pic) states it is no longer available, but you may be able to find stock somewhere (any chevy dealer can search nationwide inventory).
Tasca Parts Pass Side Step Pad
Tasca Parts Drivers Side Step Pad
This looks like the correct part for the passenger side (first link and pic) and is available for special order. The drivers side (second link and pic) states it is no longer available, but you may be able to find stock somewhere (any chevy dealer can search nationwide inventory).
also a $100, lol and one side is going to look great, so of course you need both so now it's $200
GlennSullivan
That is the unfortunate thing of an OEM part if there are no aftermarket replacements. Maybe the OP can find an aftermarket replacement somewhere. I did look at FleaBay and they have the replacement tops for the standard fixed running board but not the Z71.
Matt06Yukon
I looked for these too, I think they're on nationwide backorder. Meaning they're out of stock and GM realistically will never make more again.
mikez71
Another option is to install the standard running boards, which are functionally much better.
Less slippery, more flat area to step on.
Kevin Cervantes
Heys guys, unfortunately my driver side step has started to crack so im also looking at a replacement. Any luck finding any? I saw them on a couple sites but all passenger side only :(
If its impossible to find i guess ill just swap to some new ones so whatever yall recommend would be appreciated. Thanks fellas
Charlie207
LFOD, New Hampshire
I cracked one of mine on a trail, and found a replacement on eBay
Hodmjstone
