Does a 2024 Z51 with 6.2 require premium fuel?
gtrslngrchris
If driven hard, if the engine is working or playing hard with 87, the pcm / ecm IS responding to detected knock AFTER IT HAPPENS by pulling timing back, and possibly adding (wasting?) fuel to cool the cylinders.
The pcm / ecm NEVER learns this. It never predicts or avoids knock.
Is this not EXACTLY what the burst knock retard table is for? Pulling timing for expected knock...
It obviously needs to see some knock to retard the timing for a lower octane fuel since I don't believe it has any other way to know the fuel is going to detonate more easily than for it to just go ahead and let it do that but burst knock table has been around awhile. Never say never... or something like that.
Marky Dissod
Is this not EXACTLY what the burst knock retard table is for? Pulling timing for expected knock?
It doesn't retard timing, so much as it slows timing changes to give fueling a better chance of not going lean.
Lean however does not automatically mean knock, but it usually means more NOx.
In practice I've found that burst knock usually just dulls engine throttle response.
It obviously needs to see some knock to retard the timing for a lower octane fuel, since I don't believe it has any other way to know the fuel is going to detonate more easily than for it to just go ahead and let it do that ...
The ecm never KNOWS what octane fuel is in use, it just interpolates between the High & Low Octane spark tables.
Any sufficient TPS% increase per unit of time, and it goes back to the LOW octane table AND adds a wee lil bit o' burst knock just before it enriches a bit.
Direct injection engines can be better at preventing knock than multiport injection - operative words being 'can be'.
If I can afford a brand new vehicle, but I can't afford 91 or 93 octane, then I should buy two used vehicles and tune their ecms for 87 octane.
RST Dana
OH
I am somewhat hesitant to contribute here for fear of maybe not knowing what I am really talking about. I just purchased new a 2024 Tahoe 'High Country'. My ignorance is going to say I'm not sure what 'gas' engine I have but I will assume it's not the 6.2 being debated here? But I am going to say that I have been pleasantly surprised with the mpg's I got on a 450mile round trip I just took. On the way 'there' I averaged 24+mpg. On the way back I averaged 23+mpg. Admittedly I was only going 66mph on the highway. This is what the onboard 'computer' indicated. I think the window sticker indicated that this vehicle listed the mpg's at 14 to 18? So I am greatly happy and surprised or........the computer is not telling me the truth????
You can always check your mileage with traditional math calculations. I have a Fuelly app that I log all gas purchases for my last 3 vehicles. Sometimes I’m better than the computer indicates, sometimes I’m not.
yo' momma..... Just kidding, my friend. Not sure what kind of answer I'm supposed to give you on that one, seeing as some electronic tools are meant to visualize or audibly provide readouts.
Did you see any knock with the scan tool while driving with low octane fuel at WOT? If so, how much? That's what I mean.
You can set up some scan tools to show you which cylinders detected knock and pulled timing.
ProfeZZor X
High Country
To that, I would say no. There was no significant difference in noise, that would cause for alarm. Is there noise coming from the engine bay, yes, but as you'd expect for a 22' vehicle with close to 60k miles on it, that's the kind of wear and tear you'd expect to happen.
Hope that answers your question.
My contention has always been that most of it is too difficult to hear. It has to be measured with a scan tool.
Turning off the air and radio and putting the windows down to listen ain't good enough, been there, done that, with the scan tool running.
Geotrash
Dave
Richmond, VA
This. Need the data on how much the ECU is compensating for knock to speak rationally on any of this. But what we DO know is that running regular unleaded gas in a 6.2L meaningfully raises the risk of eventual engine damage - especially under high power.
ProfeZZor X
High Country
Just to be clear, I am NOT running regular unleaded gas in my Yukon, currently. When gas prices were at an all-time high earlier this year, I switched to the mid-grade gas for a brief period of time. During that time, which was for about a month, I did not hear any significant changes in internal combustion noise coming from the engine... No knocking, no pinging...
For $#!+$ and giggles, I did an audible test during the last week I used the mid-grade gas, then did another test a month after switching back to premium, and there wasn't any difference.
Bottom line is that no one is going to destroy their engine because they briefly switched gas grades for a brief period of time.
General Fodder
