What pipe/hose is this?
InspectahDEck
I have an antifreeze leak coming from a pipe that runs under the accumulator, however I don't know what it's called and am looking for a part number.
Video of said leak:
If anyone can steer me in the right direction it would be greatly appreciated, thanks in advanced
dps01
Senior Member
Navy Supporting Member
N. TEXAS
Video of said leak:
Looks like leaking from the tees @ the firewall, here are the GM part numbers I have for my 2003.
1 each: 15055342
1 each: 15055343
Look @ other threads in the forum regarding coolant tee’s.
Thread 'Help!!! Broken heater hose on firewall'
https://www.tahoeyukonforum.com/threads/help-broken-heater-hose-on-firewall.147959/
Thread 'Coolant Tee Quick Questions'
https://www.tahoeyukonforum.com/threads/coolant-tee-quick-questions.141234/
Most recommended using GM or AC Delco parts.
Can be a bit of a PIA to change out.
Best to change out both while you are at it.
Get it taken care of before it completely fails.
If you are changing out the Tees, you should do yourself a favor and replace ALL coolant and heater hoses, as they are probably original and deteriorate over time.
Please note that the firewall insulation is very aggressive, so wear gloves when you work on the Tees, or your hands will itch like H*ll for the next few days.
Don't get caught away from home with a shredded coolant or heater hose.
BadDaddy2003
