New to the group here. 12 Yukon XL
billyinBama76
Hey all. I’m new the the GM family and just got a 2012 Yukon XL. The driver door panel needs some attention and didn’t know if there was a part out portion of this forum. Any help someone can provide me for navigating this site would be helpful. Thanks a bunch!!!
welcome, is the handle broken? or ?
B
billyinBama76
My new to me baby
B
billyinBama76
Thanks for the warm welcome. I found someone parting out a Yukon locally and I’m getting both front door panels for 150. I feel like it’s a great deal. Any other things I should be looking out for, I’m usually a Ford guy, so GM is new to me.
heater hose's & T connectors to firewall. replace with OEM if not done already.
these are the correct part numbers, beware of bait and switch sellers that put the oem number but actually sell a aftermarket
you need 1 of each of the 4 parts
the reason OEM is stressed on this part is because the aftermarket ones will have to be replaced agian in short order, better to just cry once.
Welcome to the Forum from NH.
As @Doubeleive recommends, replace the 2 Tees in the heater hose assembly. I will go further and recommend that you replace all radiator and heater hoses in the engine bay while you're at it. If one of these hoses fails, you are stuck wherever your are at the time, and that's never a good position to be in.
canadiandux
