Headlight adjuster broken again
brucesmays
San Antonio, TX
My 21 Tahoe, the drivers side headlight had to be replaced at 13,000 miles because the adjuster failed and the bulb pointed to the ground. Last week, at 36,220 miles same thing. You turn the adjuster screw on top of the headlight and the bulb does not move. GM says if the adjuster is stripped, they will not assist me in out of warranty repairs as “this has never happened before to other Tahoes”. Dealer wants $350 to pull the headlight out and take pictures to send to GM to see if they will assist in an out of warranty repair. I am puzzled as the dealer is the only one who i have ever taken the vehicle to for all maintenance and repair work. It is also my 3rd Tahoe/Yukon is have bought new in the last 6 years. They quoted me close to $2000 just for the headlight assembly. I am just venting here as I don’t expect anything to happen.
WalleyeMikeIII
Sunny and Snowy Minnesota
Your dealer has a certain amount of "goodwill" they could provide if they choose to...depends on your business level w/ them, etc...but they definitely do have it available.
That said...who/why is someone messing w/ the adjuster? Seems like whomever it is that took a tool to it may be on the hook to fix it? Unless, the adjuster failure was present at 13K miles and never rectified w/ the warranty fix...can't tell from your post whether it was a spontaneous fail at 13k, or whether someone tried to adjust it then and it broke, then was never properly fixed...
lawoman70363
I’ve had the same thing happen to my 2021 Tahoe. Out of nowhere, the driver side headlight starts pointing towards the road. When my husband tried to adjust it, it wouldn’t do anything. I brought it to the dealer for them to adjust and they said the plastic piece was stripped and it would cost $2100 to replace (a perfectly good headlight that can’t be adjusted). Since I’ve been such a good customer they’ll do it for $1100. I refuse to pay that much, this was absolutely a failure of a cheaply made GM part. I shouldn’t have to pay that much for their poor design. To clarify for other posters, I NEVER touched the headlight or the adjuster before it fell and started pointing down. This is a safety issue and GM and my Chevy dealer needs to do better than that. I guess 30 years of business isn’t worth that much.
WalleyeMikeIII
The secret, probably was not try to adjust it yourself..if the fail occurred out of warranty (3yr, 36k miles), you probably are out of luck..but had it occurred within the bumper to bumper warranty period, a return to the dealer should have resoved it under warranty.
FWIW, the driver side healight assembly on a suburban is P/N: 85547100 and the MSRP is $1270, so if the dealer agreed to do it for $1100 you got a great deal...they basically ate the labor, and some of the parts profit (part can be had from one of the online parts houses for around $850 + shipping).
This is the state of things these days, all these manufacturers are building custom headlamp assemblies...I sure miss the old days of the sealed beam lights that were $10 and two philips screws to replace...that said, the performance of these LED lamps is way beyond those old sealed beam halogens.
Lanyx
I think I found the problem. I have a 2021 Suburban LT. Same exact issue. You can remove the adjustment knob by using a wrench and turn the whole adjustment assembly Clockwise 45°. It will pull out. Be very careful from dropping it as it is crazy hard to retrieve! You will notice that the adjustment screw end is connected to a white pin (don't know a better word). This pin is ribbed that connects to the actual interior light assembly. The pin literally is 1/8" of plastic and any hard bump from rough roads will break it. This is destined for failure. All we need is a replacement part and easy fix. But I can't find this part anywhere. Should be a $5 part considering the way it is made. I cut a hold in the top of the headlight about 1.5" in size directly above where the pin connects to the interior light assembly. Screw the adjuster all the way out to extend as far as possible with the pin attached. Hold the adjuster with pin into the hole. Drill a 1/16" hole in the assembly and through the adjuster pin. Put a 1/16" nail in the hole through the pin. Screw in the adjuster until it starts lifting the interior light assembly and remount the adjuster by turning counter clockwise 45°. Adjust your headlights to the proper height. Seal the hole with good duct tape or whatever you find best. Been working now for 6 months.
Bdbdzz
same issue here, broken adjuster
riptusk331
did you attempt Lanyx's fix? i am having the same problem on my 2021 Suburban that's out of warranty and was going to try it out if badgering the dealer for goodwill fails.
riptusk331
i've been googling around this issue, and it's definitely a defect in the way the adjuster assembly is designed...cheap plastic used and seems to be giving out for folks right around the 2-3 year mark. there's a thread over here on the chevrolet forums where people are talking about the same issue. one of their headlamps all of a sudden pointed down, never touched the adjuster.
i will update with how i fix this and make sure to post here.
Bdbdzz
I just made a quick fix by applying glue to the head of the adjuster and then reinstalling it in the headlight. Make sure to wait until it gets dry. It works for me.
New Guy
I too used this as my fix. Thanks for the suggestion! It worked really well, make sure to measure before cutting, ensure you don’t cut too deep and hit the electrical work inside (look through the headlight lens to verify), and the hardest part was cleaning out the debris after opening up the top of the headlight. I used a small shop vac with an attachment to get plastic out. I used a hole saw so I could JB plastic bond it back together, make sure to let the epoxy harden a little so it doesn’t drip down in the reflection surface. I used a 1” finishing nail and a 5/64 drill bit for the fix.
I did this because I can’t stand the thought of paying $2000 to have the same problem because they install a light with the same engineering problem. Not only that but it’s only a matter of time before the other light does the same. Instead this is a stronger fix for $25 between the JB Plastic bond, the box of nails, and the drill bit. I did use a drill, a 3” hole saw bit, a shop vac, a microfiber cloth (to wipe smudges inside the light), and a measuring caliper (to measure and mark where to drill the finishing nail hole as to not puncture the black ball). These were all items I already had.
Here are photos of what the inside of the adjuster looks like when broken, what the inside of the headlight area where the adjuster connects to it. Also, here’s a picture on how I decided where to cut my hole, where I drilled/pinned the adjuster, and a picture of the hole sealed back up with the JB plastic bond.
Take your time and focus, it’s not too hard. Hopefully this helps! Lord knows it’s worth saving $2k!!!!
riptusk331
Wow, great post New Guy -- super helpful to see what the inside of the assembly looks like from the top down. Glad you were able to resolve it!
After fixing it that way, do you think your method and all the cutting/drilling/mess is worth it, or could I get away with just putting JB Weld on the adjuster head and then reinserting it and letting it dry (like Bdbdzz mentioned)?
New Guy
It might work if you’re lucky. The main problem is that when the chrome piece doesn’t have the adjuster attached, the chrome piece won’t be aligned to reinsert the adjuster with the job welded white piece.
I liked the route I took because it’s a stronger fix that operates just as good as oem equipment (just more reliable).
The big thing I would call out is not to get jb weld on the connection between the white part of the adjuster or the sphere that is on the adjuster as the light won’t be able to adjust due to the adjuster not being able to spin freely.
Overall, I would say it is a 65% chance it would work, and a 35% chance that it caused irreversible damage that would require buying a $2k replacement light.
West1
Having the same issue on my four year old 21 RST Tahoe @50k miles.
cstapp99
Thanks for posting this fix. I plan to do this myself also. Your photos are throwing me off a bit. The one with the drill marks on it and the one with the epoxy applied don't look like they are photos of the same headlight. Is that the case? It just looks like the "made in Mexico" label is reversed on one of them. Thanks!
cstapp99
Thanks to the description from Lanyx and the added photos from NewGuy, I tackled this fix today. It’s about an hour job and most of that is epoxy drying time. I will note that there is a small area of opportunity for the nail to hit without accidentally interfering with the rotation of the black threaded rod that needs to be free to spin. It will all make sense once you take it apart and look at how it goes together.
micdzi
does anyone have a picture of the good headlight adjuster? any chance to model it and then 3d print?
West1
When you epoxy it back, are you able to adjust the headlight as if nothing ever happened or do you need to glue it to the desired height in one shot?
West1
Which direction did you go, drilling a 2-3” dia hole above the light or pulling stuff out from the adjuster side?
Tahoe Rob
I had the headlight problem so came upon this post. 2021 Tahoe LT that just hit 50,000 miles and the driver side headlight adjuster broke. I used Lanyx's fix, with the help of New Guy's additional post and pictures.
This all makes way more sense once the hole is drilled and you see the assembly. I did not remove the adjuster before drilling a 2 1/8" hole thru the top of the headlight assembly, there doesn't seem to be a need to remove it.
As of today, an entire replacement assembly is priced at $1,267.63 on parts.chevrolet.com and $851.12 on gmpartsgiant.com. I figured it was worth a shot to save at least $850. I consider myself handy but certainly no mechanic or machinist. This entire fix took me under an hour from hole drilling to final headlight adjustment and even left me time to search for and order the grommet to plug the hole. I had everything on hand, except the grommet that I had to buy 4 of and ran me $7. (2 1/8" because that's what I had from drilling door lock sets).
I held a shop vac to the drill bit as I made the hole, but still get some plastic shavings in the light. I vacuumed what I could out and used some compressed air to blow out the rest out.
The part that had me confused about the previous posts was I didn't understand that the nail stays in a vertical position once it's put in. I was picturing that it spun with the assembly when adjusting, and didn't see how it either didn't fall back out when inverted, or didn't see how there was clearance to spin. But again, this all makes way more sense once you have it opened up.
I used gorilla tape to seal up the hole for now until the grommet gets delivered. I'm going with the grommet instead of epoxy in case for some cursed reason I have to get back in there at some point.
Seems like this is a better fix than the original design. Thanks Lanyx for posting and New Guy for expanding. Hopefully these pictures will help show more of the process for the next person to come across this.
JamesinAbilene
