Fuel Gauge Wonky, Removed Cluster
donjetman
Replacing the fuel sender/pump module in the tank didn't fix my fuel gauge with a mind of its own. So today I removed the instrument cluster from the dash and will take it to a local shop tomorrow to see if they can fix it (maybe a bad driver). Maybe even get it customized :)
http://swtauto.com/
tom3
Son had several problems with this, finally quit all together. Sent it off to an outfit called Circuit Medics for a rebuild. Nice and bright with all new lamps and all working fine. Was right at $200 for this two years ago.
donjetman
donjetman
Local shop loaned me a good used cluster. No change. Fuel gauge in loaner cluster acts wonky too.
Local shop thinks there a bad ground or chafted wire somewhere since I've already changed the fuel pump/sender module.
I ohmed my old sender thru its range of motion and it looked good/linear, no spikes or dead spots.
I'll keep looking for a bad wire/ground under the vehicle.
petethepug
Michael
SoCal
Grrr, that’s frustrating. Is there a way to get into a harness connector somewhere and connect a new, known working sender to isolate where the issue may be in the harness?
petethepug
Michael
SoCal
Just a thought. The temp gauge in my 09 will get a mind of its own about every two years then, back to normal.
The only culprit I could narrow it down to was driving in heavy at highway speed. I was going to swap out my battery cables and replace the BCM if it didn’t stop.
Got silverfish in the tank getting on the level sender contacts jumping the circuit?
donjetman
donjetman
I don't know what "silverfish" is???
I installed new fuel pump and level sender. No change. Inside of tank was clean.
Ohmed the old sender and the graph was smooth.
petethepug
Michael
SoCal
It’s not u, I have a carton mindset. Silverfish, bugs that look coated with silver powder, at least here in so cal. We always joke about them causing any of our electrical issues around the house.
mikez71
Maybe vapor pressure sensor messing with the fuel level signal?
JasonW4141
