Finally got my housing changed
iboughtatahoe23
Any way I can get the new driver side housing to fit as flush as passenger side? Both are after market housings. Did I do something wrong
iboughtatahoe23
iboughtatahoe23
Seems like ever since I took the driver side out I haven’t been able to get the old one or the new one to fit right.
iboughtatahoe23
iboughtatahoe23
A year ago vs now. I know it can be done. The old one was aftermarket and fit perfectly.
St. Louis
You talking about the gap underneath and the top edge not lining up with the center grill?
If so, that has to do with the front bumper cover alignment. There should be some play if you loosen the bolts across the front above the grill
iboughtatahoe23
iboughtatahoe23
Hm I never removed any of the bumper cover bolts. Just removed the wheel well splash shield partially and than partially removed the bumper cover as well just enough to take the housing out
iboughtatahoe23
iboughtatahoe23
Like you’re saying if I loosen the bolts a bit I can get it where I want to? That makes sense if that’s what you mean
St. Louis
Probably. The front bumper cover has a hard foam insert across the front that fits pretty snug into a horizontal groove in the metal front bumper to help support it, but the bolts across the top above the grill and in front of the radiator cover do allow for adjustment of where that entire thing lines up.
Pic of my Yukon with front bumper cover off, but a Tahoe is the same. Only bolts holding bumper cover on are across the top, a coupe in each wheel well, and one on each side underneath behind the fog light/tow hook area.
iboughtatahoe23
iboughtatahoe23
I tried taking it apart again I couldn’t figure it out lol. Can you be more specific about this Groove the bumper goes into? That seems like it would help me.
Tbh I might just leave it. I know the headlight is secure. It seems the bumper is just a few hairs off. But I dont think it is affecting anything
iboughtatahoe23
iboughtatahoe23
Starting to think it’s just the headlight housing idk.
I wouldn’t need to remove any bolts if I didn’t remove any in the first place, or?
I must’ve just pulled the bunper cover to hard and than wasn’t able to properly align it on this alleged groove. Idk.
St. Louis
I updated my above post with a pic.
Shouldn't have to remove the entire bumper. There are like 4-6 10mm bolts across the top and I think 1 7mm bolt on each side (at least on my Denali bumper cover, a Tahoe may not have those 7mm bolts). Loosen all those up and grab the bumper under the grill opening with one hand and lift up while tightening a couple of the 10mm bolts across the top.
iboughtatahoe23
iboughtatahoe23
Man this is bugging me
Here is an update in regards to this photo. I took the new housing out, set it aside, grabbed the old one, used epoxy to fix it, put the old OEM housing In got everything secured and back together and here is where I’m at… a little better but i think it is safe to say it’s the bumper. Maybe one of the clips snapped when I pulled it off partially? Idk! I just did what the 1a auto tutorial said.
In the 2nd and third photo I am showing how the passenger side compares to the driver side with the fixed OEM installed. It still slacks a bit in some areas in my opinion
Just Fishing
Can't fix stupid
Utah
Man, you should see my headlight gap.
I made a transmission cooler mount and the place i found to bolt it up also has something to do with the bumper cover gap.
It looks like my tahoe is tired now.
iboughtatahoe23
iboughtatahoe23
Yea after two days of tweaking over this I think it is time to throw the towel in
