Which shocks to buy?
mountie
From the www.kyb.com/catalog:
For anything, stay away from the Excel-G shocks -- get the Gas-a-Just or better.
How long have you had this SUV, and can you tell if the PSR shocks in the rear were converted to standard shocks? That conversion can be done if the rear coil springs are done at the same time.
Rock Auto has the PSR Nivomat replacement shocks under the GM Genuine and KYB brands.
What do your current shocks look like, and do the springs still have the tags on them? Here's what the OE Nivomat shocks look like. They're quite a bit fatter (more girth) than standard shocks.
I still have the OEM stickers on the springs. Matched for the " ZW7 - Premium shocks" NOT self leveling, so the springs are a tad stiffer, than the 'self adjusting' shocks. ( self-adjusting shocks support more, requiring a softer spring)
My shocks are the OEM 'blue' color. They just have 175,000 miles on them, so I figured, new - same "should" perform better than old.
Edit.... The sticker on the springs shows the part number and then, below, that 'designation' (?) "YKK" seems to be on a few different springs.....
D
diezelraccoon
I’ve had the vehicle about a month now. Here’s is what’s currently on it.
All this back and forth is kinda confusing. I was told look in the glove box and the number will tell me what I need and now the conversation just seems to be well that’s not ac
Those are the OE RPO G65 self-leveling (manual) shocks that use Nivomat technology. You can replace them with like shocks (I noted them in a prior message), or convert to conventional shocks as long as you change the coil springs, too. If you change only the shocks to conventional (but not the springs), the ride will change for the worse and will likely be too soft. You could use shocks spec'd for a Z71 along with Z71 springs, as an example.
I'm curious though -- what reason is there to change them? You can test if they're working by 1) measuring the rear bumper height; 2) loading the back end with a few hundred pounds of weight; 3) measuring the height again -- same spot -- for the amount of sag; 4) taking a drive of a few blocks while they self-adjust; and 3) re-measure the height again to see if it came back up, and how much. Then unload the ballast. Be sure to make your measurements with it parked at the same spot and orientation for the best accuracy.
I'm still running original rear shocks on mine, and they're working fine.
D
diezelraccoon
When you are traveling at highway speeds and hit a bump, it bounces like the Watusi. If you don’t have control of the steering wheel and hit a big bump going highway speed, you could lose control. My shop diagnosed them and said they were bad.
Can’t believe how expensive just one rear KYB shock is for over $300. Am I seeing that right?
mountie
A good guy.... ( Truckee Salvage) Has been finding & selling very good / used shocks for years. He sent me a set of Nivimats . But I later discovered I don't have Nivomats ( due to my confused searches)... I will be returning them back to him.
mountie
I googled the part number and that’s what came up. You have a link to somewhere else?
The self-leveling shocks are expensive. $300 to $600 each depending on your brand- version... The Nivomats I purchased from Truckee Salvage was about $360.00 for the pair. Over 1/2 the price for new- unused.
But if you are not going to haul a heavy trailer, I don't see the need for Nivomats.
Toomanyhobbies
Bilstein 5100's all the way if you are going to keep the truck for a long time it's worth the investment.
Yes, they're expensive. That's why some folks will replace with good used ones, or convert the shocks and springs to standard if they don't need the adjustability. Hopefully your shop is familiar with the self-leveling shocks (many aren't up to speed on how they work) -- did they give you an alternative or other solution?
Is the suspension fully stock or has it been lifted, lowered, or ??? Do the jounce stops in front touch the lower control arms at ride height?
TahoeRestore
Needing new front and rear shocks on my 03 rear wheel drive Tahoe. I don’t really want to spend a tone on them. I saw a set of 4 ACdelco gas charged shocks for around $190. I tend to stay away from super cheap ones like Duralast. Just want something that’s gonna give me a comfortable ride like it was when it was new and not spend a time. I’m just a daily driver. Mostly decent roads, sometimes towing on occasion.
Any thoughts or suggestions?
I recently finished a complete steering and suspension (except springs and torsion bars) restoration on my 2003 Tahoe which has 160 K miles and the ZW7 & G65 Premium Smooth Ride option. My steering was getting really loose and one of my rear shocks (Nivomats) was leaking. I replaced both with Nivomats (SACHS 030239 @ $280 each).
X-ray Nerd
