Left accesory outlet no power
gdddup
NJ
Ive got no power at the left side accesory outlet. Checked wires at the back of outlet and fuses, no luck. Right side, both console and rear most all working perfectly. Is this drivers front outlet on a separate circuit or something I'm not seeing?
yes and no, the left power outlet is tied in with the obd data function and is seperate from the right power outlet, most likely a bad fuse, double check and/or replace the fuse anyway. there may be 2 fuses to check one behind the drivers side left dash cover and one in the underhood fuse box. owners manual should show which ones, also check the accessory power fuse.
gdddup
gdddup
NJ
Thank you I was unaware that was tied into obd data. I will look into it once things cool off outside hahaha
CKendrick
