2016 Yukon Denali compass
Rickjk
Hello,
It’s not working. Is this a fuse issue perhaps?
Thanks,
Rickjk
Hello,
Thanks,
Rickjk
you could try doing 2 things
1. drive around in a circle several times each direction in a area with clear open sky @5 mph or less (like a open dirt lot or large parking lot, anywhere there is room)
2. if the above does not work then disconnect the battery for about 5 minutes then go do the above.
there is no fuse
if you do the battery disconnect it should say "cal" which stands for calibration, which is the above (driving in circles slowly)
if that doesn't work then it's possible the gps antenna has a issue
PexoA78
