Copper Clad Aluminum wire on an auxiliary battery installation
opfor2
Riverside County, CA
I'm getting ready to install an auxiliary battery set up on my 2011 SSV, and I'm wondering if I should be concerned about using Copper Clad Aluminum (CCA) primary automotive wire verses pure cooper?
mikez71
I don't trust it.. but I don't know anything about it.
For smaller wires, I ordered some sxl wires from ebay. You get enough length with a selection of colors.
The insulation is less soft and can take higher heat. Probably didn't need it, but it feels better :)
Battery cables, sounds like SGX > SGT..
SnowDrifter
Sasquatch Country
Nope don't touch it
Stuff isn't suited for under hood use. Copper + aluminum react via galvanic corrosion. You also can't solder it, which means you need a crimper. And, politely, a bench vice doesn't count!
Use marine grade wire - tinned copper. It'll hold up to the chemical/moisture exposure
IMO, you should use solid copper wire instead. It has a much lower internal electrical resistance and is subject to less corrosion.
Scrappycrow
Air Force
Alpharetta, Georgia
I would only use copper. Size the wire for the length & amperage, then consider the wire and the connectors as a system. I prefer using solder terminals that utilize solder pellets, then sealing the joint with heavy-duty adhesive-lined shrink tubing.
Some sources besides those mentioned above:
strutaeng
Dallas, Texas
I didn't know they had that for battery cables. I have used that copper clad for speaker wires before (in-wall).
And aluminum wire is still used in main feeders and stuff like that on buildings, just not individual branches like they used in the old days. My main panel to detached garage subpanel is aluminum, which is like a 80 A or something) that's used for welders, air compressors and tools.
You can always buy the next size up to keep the wire from getting loaded as much.
j91z28d1
whatever wire you use, please don't solder battery terminals. crimp and if you must, solder after crimp.
petethepug
Michael
SoCal
Good question. Good info. Aluminum was supposed to be the fix for rising copper prices. Aluminum contracts & expands from thermal loads. That loosens the connectors made of dissimilar metals. Loose connectors means arcing. Arcing started fires.
Aluminum is ok for power as long as it’s up to code and using connectors that are rated not to interact. I can’t figure why they’d make CCA for automotive use when it’s in play, live, literally moving and susceptible to damage as any vehicle is.
waveryd
IL
Yes, you should.
waveryd
IL
I use batterycablesusa.com a lot. They are reasonable with high quality USA made wire and fast shipping. You can design any cable with any ends on their site. Excellent crimps with good heat shrink tubing.
ZKWBQD
If you have a choice, I would definitely go with pure copper.
73Vetteman
I use copper welding cable. Flexible, available by the foot, and easy to alder crimped connectors.
j91z28d1
wait. will they make cable to your spec. crimp whatever ends you want, heat shrink and send them to you?
if so that's brilliant for the guys that don't do wiring stuff and just need a few replacement ground cables here and there. maybe a upgraded alt wire with a different terminal than stock.
Dh1280
