iphone with usb port
robsieb
Apparently GM now has a fix that they are sending the service manager I've been dealing with. I've been told that it's not yet available to everyone but they are sending it to him to update my radio. Looks like I'll be the Guinnie pig. Fine by me as long as it gets fixed.
He's supposed to contact me once they have they update and I'll schedule a time to have it done. I'll report back what happens.
robsieb
Finally had a chance to take the Sierra to the dealer for the update. There's good news and bad news.
The good news - The update mostly fixes the popping noise. I can plug the iPhone in and play songs or podcasts, skip from one song to the next all without hearing the popping. So far I've gone as long as an hour without having to disconnect the device due to popping and this was only because I was getting out of the truck. It may be just my imagination but I actually think the sound quality is better too.
The bad news - The popping can be made to happen. If you're listening to a song and hit the FF button for a few seconds the popping starts again and the only way to stop it is to reconnect the device. This also brings up another problem. If during the popping noise you switch over to a podcast (and I can't say for certain if it's just podcast) it will not play. Nothing, no audio at all. The information about the podcast shows on the screen, you can switch from podcast to music but no audio at all from either until you reconnect the device.
Part two of the bad - The charging may or may not work. This issue does not seem to be resolved at all. The first day after the update I could get about 10 minutes worth of charging but then the iPhone would throw up the "Device not supported" message and charging would stop. Also, seems that the first time you plug the device in after it's been restarted the radio will not connect. You have to pull the cable and reconnect. Most times now it will charge for about a minute and quit.
Part three of the bad news - During playback, be it music or podcast, at any given time (I haven't been able to see a pattern yet) the audio from the iPhone drops out, not all the way, just a quieting down for a split second. It's hard to describe but I guess I would say it sounds as if the signal weakens for just a moment and then goes back to normal.
Part four of the bad - Pressing the FF button a few seconds or a few times during the playback of a podcast causes the above symptom of the audio stopping completely.
Am I happy? Somewhat. I no longer have to constantly disconnect the device to stop the popping. Could I live with it with the other problems? Possibly. I very seldom use the FF key so I probably wouldn't have a problem with the popping. Is charging an issue? For me, not really. I usually am in the truck no more than an hour at a time. For me the update is bitter sweet or one step forward and two back.
I've sent an email to the service manager who's forwarded it to engineering so now we wait but at least I don't have to keep reconnecting it to stop the popping. Currently I'm supposedly the only one who's received the update which was done using a USB flash drive in the USB port in the console. Engineering has yet to release this to the general public and I would hope that after reading my email they will go back and have another look before putting it out there so for the moment I'd recommend holding tight. As soon as I hear something I'll be back with the details.
swacker69
Htown
Rob
Your the man dude, thanks for the update. I was waiting to see what happened with your scenario before I took mine to my dealer here in Houston. My dealer wants to change this piece and that piece and before you know it the entire freaking car has been swapped out and your still at square one! Please keep us informed
Greg
robsieb
Greg:
Yep, save yourself the trouble right now. I've already had all that done, even had the entire console and seats out replacing a wiring harness just to find out that it's a firmware issue as I told them it was in the first place. Now they just have to get it right. As soon as I hear back I'll let you know and if I can get a PI number from them once it works to save everyone having to find it.
Rob
jKipler
My nano has worked in my '07, maybe its a cord problem? I don't know too much about it, I'm kind of new to all this stuff.
swacker69
Htown
I have done the following. Bought a new nano and bought a new cord. Same result. I have used a USB Stick and no issues what so ever. Leads me to believe that Apple and GM arent playing well with each other.
Cabowabo
I'm having the same issues with the iPhone/iPod in my 2010 Tahoe. Is there any easy way to convert my iTunes library to mp3 so I can put it on a USB drive?
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
yes. as long as it isn;t downloaded from the itunes store.
highlight the tune and choose create mp3 version from the menus.
SabrToothSqrl
Why is GM bothering with these silly cables? Iphone 3GS (and a TON of ford products) support the A2DP bluetooth profile... stream your music, don't hook up a stupid cable... Has everyone seen 'My Ford Touch' it kicks the shit out of anything GM has... I'd sell my Tahoe for a 2011 Edge if the Edge could tow what the Tahoe can... I have an 09LTZ, and GM cut me a check for the voice destinations not working ($900) last year sometime once I got the BBB involved... this piece of crap headunit was designed by 80 year olds for 80 year olds. I know my 15 year old sister could have designed a better system... that I don't know... WORKS. or does something that's actually useful... Where's the weather? where's the free traffic? where's address entry in motion (honda lets me do it!) the ipod/iphone only have 99.999999% of the market, hey I know... let's NOT test our products with them... that will work :)
PC3000
Iphone ios4 with USB Port Problem
So i just bought a Tahoe today with a Nav Bose system and learned that my iphone 3gs with ios4 will not connect. It does not Charge either.
A few months back, I remember that i tried my iphone 3gs with 3.1.3 software and it worked with a non nav system in the tahoe.
Is anyone's iphone working???? Is it just a problem with ios4?
I read the posts and it seems that there is no fix yet. However, there is one post that came up and someone said to try a "Peripheral by Media Gateway" from Crutchfield. Has anyone used this? How does this connect to the iphone and tahoe?
Eagle
EL PASO, TX
yes the problem is your iOS4.
As an undisclosed "feature" iOS4 added authentication for accessories, so anything without an apple chip won't work anymore.
Peripheral's PXAMG media gateway is user upgradable: they have a chip that can be added to the control unit and firmware flashed to support iOS4. Unfortunately the chips are backordered until at least July 5th.
PC3000
Maybe i'm a bit confused. According to their application guide I need the following
"All radios must have a “BAND” “XM” “P-TYPE’ or “CAT” button otherwise they are incompatible.Not compatible with Monsoon systems. (PGHGM5)".
It sounds like you are familiar with my Nav Unit. I do have XM and I do have AUX.
Now if I purchase this product, how does is connect to my vehicle and how do i flash the chip. Sorry for the confusion, it's not my expertise.
Eagle
EL PASO, TX
it jsut plugs into the back using the OTHER cable supplied... GM11 I think it is.
It has a pigtail that lets you plug it in and also has the female side of the socket like the oem head so you can reconnect your OEM accessories.
You flash the firmware using a USB cable and your home computer. Software is supplied on the website.
You install the chip by completely disassembling the unit, draining the capacitor by shorting it with a srewdriver, and carefully removing an existing circuit board and replacing it with a newer one you purchase separately from PAC.
My suggestion? wait until they start including the update in the retail version... they will probably have one soon that says "iOS4 compatible" or "iPhone 4 compatible" on the packaging just like they did when the new 5v only charging scheme for the iphone 3g, nano 4, and Itouch 2g came out.
PC3000
Ok, so i did a bit more research. The question i have is, will this be in place of my XM Radio or can i still have both XM & my Iphone.
Eagle
EL PASO, TX
both.
can also have Aux in (supplied)
or
Bluetooth (extra module)
or
Sirius (extra module)
or
HD radio (extra module)
PC3000
Thanks for you help man. I just sent an email to PAC-Audio.
JeffK
