6.2L Rough idle and poor low RPM response
apex944
Just took delivery of a brand new 2024 Yukon Denali.
Immediately upon pulling away from the stealership I noticed what appears to be a slight misfire at idle and a very slight hesitation upon throttle take up in drive. I'm pretty familiar with engine tuning as I race cars where I program the ECU... so really dont think it is my imagination. I dont think its a complete cylinder miss but more like an intermittent or weak fire. I have no diagnostic tool for this engine (yet). Didnt think I'd need it yet. LOL.
So my question is... has anyone experienced such a low RPM miss ?
Also, I think I know the answer but is there any 3rd party software to (permanently) turn off the damn auto engine start? It jerks so bad when pulling away from a light that I spilled my coffee all over. (yes even when barely giving it throttle). I actually do wonder if the low RPM problem noted above is causing the autostart issue.
66 Galaxie
I don't have the miss fire issue you describe with the 6.2 in my 2022.
Autostop Eliminator will handle the auto stop-start challenge
KMeloney
This. Finally got around to installing mine a couple weeks ago. So nice to not have to deal with the stop-start anymore.
Vinnoto1
I have a 2022, when sitting at a light it revs down to about 500 rpm and sometimes feels like a miss fire. Auto stop is a headache, the other day I forgot to turn it off and hit the gas and the engine stalled before restarting.
StephenPT
St. Helens, OR
The auto-stop eliminator linked above is fantastic. 15min to install and 100% satisfaction. Plenty of videos/threads about installing it on this forum.
KMeloney
The Auto Stop turn off button is likely the first thing that will wear out on our Denali. I turn it off every time I get in the thing.
...Or you can get the Autostop Eliminator and never deal with the button again.
iamlegion
Does this only happen when cold or warm too? The new gen engines are much more complicated at cold start up for emissions requirements. It’s normal to hear timing tick (not knock) during initial start up.
the hesitation- is it audible only or do you feel it? Have you drained the tank and put in top tier 91+ octane? The dealers are cheap and rarely put high octane in while they’re on the lots.
if you’ve run good top tier high octane through and you feel (not hear) a stumble I’d take it back to have them check it.
apex944
apex944
Just bought it. Thank you.
tj40371
Our 2023 exhibits the same characteristics from time to time, but much more prevalent in the first few thousand miles (like nearly all the time). Dealer never found anything wrong and now at 17000 miles it is mostly smoothed out.
apex944
apex944
Thx, good to know. I'll have dealer take a look and then cross my fingers if they dont fin anything.
jbooose
I experienced the same rough idle issues you described when I took delivery of my 2021 Yukon Denali. It was definitely a rough idle and you could feel the engine and car slightly vibrate/shake. It did not occur all of the time though and I always used the correct octane fuel. If I applied just a bit of throttle to raise the RPMs up by about 100-200, it went away.
Dealer looked it over but said because there were no codes there was nothing they could do. They also told me they could not adjust the idle speed without a real "issue".
I now have about 34K miles on it and it rarely, if ever, happens now. Hopefully yours will go away too as seems to have happened with me and others.
apex944
apex944
Thanks. I just did my first real "tow" this past weekend. 20' steel enclosed with car. About 5500-6000 lbs I would guess. At lower RPMs (even way above idle) it does feel rough. Just doesnt feel smooth at all with part throttle loads.
WalleyeMikeIII
Sunny and Snowy Minnesota
It is possible this is transmission shudder vs. engine...worth taking it in and ask service manager to take a ride w/ you.
Techs can hook up diags and drive it, or have you drive it, and monitor things...Misfires are reported as are fuel trims, and a bunch of otther stuff...
JVega
I have a 2023 Yukon Denali, with the 6.2L engine. I was told this engine hesitation is caused by the DFM (Dynamic Fuel Management system). On my older 2019 Yukon Denali I never noticed the hesitation. On my new 2023 I have noticed it quite a few times, it normally lasts a second or two. The first few times it scared me thinking the engine was going to stall or something. My truck has a bit over 5000 miles. The DFM is what shuts off several cylinders at a time if not needed to save fuel. I wish there was a way to disable it, but it does not seem possible. My 2019 also had the 6.2L but I am not sure if it had DFM, or the older AFM (Active Fuel Management). The reality is, we but these trucks with the big V8 engines to have all the power possible at all times, I wished the government did not force the manufacturers to create all this BS which diminishes the beautiful V8s.
ChrisYukon
I had an occasional rough idle in my '17 Denali. The dealer ended up replacing the engine mounts at 30,000 miles under warranty, and it never happened again. It was a problem they were searching for at every service.
apex944
apex944
After driving for another 300-400 miles I can say that its usually more of a transmission issue. The 1-2 shift is consistently poor.
Even with the slightest of throttle applications (which I realize these days is not just the TPS and my foot, but an algorithm) it go 1st THUNK 2nd. Jerking relatively hard as 2nd engages.
I did speak with the dealer and one of the service managers said his 6.2L did the same thing. He was just living with it.
Hopefully the trans ECU learns over time as some suggested it might.
KMeloney
I’d say that mine might do the same. Not so much a thunk, but it’s not particularly smooth. The whole trans is better than my ‘09’s, though, so I’m ok with it (for now, anyway).
dizhai
