Possible trailer plug/adaptor problem
GMT800 2005 Tahoe Z71
Navy Supporting Member
By the way, the 15 amp blown fuse I found was for the trailer park lights and that was in the under hood fuse box and the 10 amp blown fuse was for the trailer right turn signal.
Airman68
Kaukauna, WI
Interesting. My trailer lights work except for the left turn and brake. It is the truck, tested with a meter. I'll have to verify the fuses.
Check fuse #3 in the underhood fusebox.
TCOLL5830
I have similar issue on 2015 Tahoe LTZ. I bought a tester to confirm it was not the trailer. (I also checked trailer side by connecting another vehicle and all trailer lights work). Vehicle rt tailights/turn/brake lights all work correctly. So problem is somewhere between connector and the main rear harness. I am betting on connector based on comments on this thread. How difficult is it to swap out the connector ? Are the trailer circuits for brake/turn on their own fuse ? Is there a place on this forum to get wiring diagram ?
This thread is for 2000-2006 series. I would recommend posting in the appropriate year for your vehicle, since the wiring and electronics can be different.
Welcome to the forum from Oregon.
TCOLL5830
Hello OR VietVet,
Welcome home. And thanks for confirming my post made it to cyberspace.
34 years USAF
TC
TCOLL5830
Thanks Fless.... see what happens when newbie's join ? I'm trying to navigate my way around this forum... will try again
The Whip
