03 Tahoe Power Amp Running Boards
Trey Hardy
Anyone have a line on amp powered running boards for 2003 Tahoe? Anyone install them successfully?
Thanks
Curious as well. I’m sure you could rig up some 07+ factory power boards to work but I have heard the factory boards have more issues then the amp steps do especially if live in salty conditions.
mjpeterson
I'm getting ready to do my 05 Z71 Tahoe. Removed the steps and plastic easy enough and now I'm looking at 20 fricken rivets to remove! Will keep updates here. well, got all the factory crap off. Passenger side was a pain due to the coolant lines, trick was to tap out rivet pin and then knock the heads off with hammer and chisel. Installing the Amp Reasearch steps is pretty straight forward mounting the hardware, BUT the wiring is a pain in the arse. will be back to update, ask a question.
Dantheman-2003
Dantheman-2003
Placerville, Ca
I'm getting ready to do my 05 Z71 Tahoe. Removed the steps and plastic easy enough and now I'm looking at 20 fricken rivets to remove! Will keep updates here. well, got all the factory crap off. Passenger side was a pain due to the coolant lines, trick was to tap out rivet pin then knock the all heads off with hammer and chisel. Installing the Amp Reasearch steps is pretty straight forward mounting the hardware, BUT the wiring is a pain in the arse. will be back to update, ask a question.
Awesome and best of luck. Where did you order the amp steps from?
mjpeterson
Realtruck. $1649. 1777. OTD. Good price and real quick delivery. It was easier installing the kit than it was removing all the plastic oem steps!
koomie98
