07 tahoe z71 BILSTEIN rear shock
Sawa
Hello. The car is a 2007 Tahoe Z71 4WD. I'm having trouble with my Bilstein rear shock.
I would like a 2inch lift.
24-187237 seems to be suitable for the normal height, but I would like to use 24-185783.
I use genuine z71 coil. I don't want to use spacers.
Please give me some good ideas.
Sawa
Sawa
Trey Hardy
Most of the bilstein 5100s you’ll find online will be for 0-2” of lift or for 2-4” of lift
Sawa
Sawa
Thank you for reply.
24-187237 or 24-185783.
Which do you think is better?
blackelky
The z71 coils after settling are .8-1.5 inches of lift nothing crazy
Sawa
Sawa
Probably meant 1-1.5” of lift from the springs
Either of those shocks should work fine for your application but if weary get the second set you posted that’s for 1” of lift
The coil springs have been used for about 200,000 miles.
I feel tired and weak.
Is Bilstein 5100 24-185783 recommended as a choice?
Desired lift is 1.5-2inch.
The damper (shock) isn't intended to raise or lower the suspension. The length and travel are meant to match up with what's needed for your lift (done by springs, etc.)
Trey Hardy
Bilstein 5100 Series Set of Rear Shocks fits 2014 2018 Silverado 1500 4WD with 2" Lift | Includes TrendsAuto Decal | 24-285896 https://a.co/d/9sqWL3g
These are the ones I used when my Tahoe was leveled it says for a Silverado but they work on the rears from 99-18 or higher
Sawa
Sawa
thank you! Can this be used with a z71 coil spring without a spacer?
man n black
Does this truck have auto rear level?
If so you do not need any kind of rear lift as when you lift the front via a torsion bar lift keys it wil automatically raise the rear of the vehicle. This will gain you between 1 and 1.5 inches of overall lift. Only shocks are needed.
Sawa
Sawa
1.5-2inch lift
Which one should I choose?
BILSTEIN 5100
24-185783
Compressed
Length
16.12"
Extended
Length
26.14"
Shock Travel10.02”
24-187237
Compressed
Length
15.55"
Extended
Length
24.33"
Shock Travel8.78”
24-285896
Compressed
Length
16.57
Extended
Length
26.20”
Shock Travel
mikez71
first one has the most travel.. third one only has .06" more length..
My pick would be #1 (24-185783) unless #3 has some other advantage..
tahjoe
@Sawa did you end up going with the 5100s in the rear? If so could you share the part no?
petethepug
Michael
SoCal
Nice!
Enjoy piece of mind & lifetime warranty.
brice715
