2015 Chevy Tahoe window problem's
Domenic Madeley
Hello I have a 2015 Tahoe PPV my back Windows have gone down but will not go back up. I have already replaced the master switch, fuses and nothing seems to be working. If anyone knows or how to fix it let me know. Thanks in advance
might take a bit of troubleshooting to narrow it down but if you need them up you can apply 12v directly to the motors and put them up in the meantime
it has been reported that wires can come loose, not sure where precisely but there is a junction from the drivers door to the body I would look there and see if anything looks amiss
if you pull the rubber cover back where the door harness is against the body in the door jam you will see where it connects, there is a opposing connector inside the body.
D
Domenic Madeley
Gotcha I appreciate that I'll have to try that out. And also the drivers door dose swing out a lot farther than the rest so maybe that has something to do with it.
jos1098
