Upgraded from a 2008 Denali to a 2009 Eski
petethepug
petethepug
Michael
SoCal
I saw that one pop up on my eBay radar. It could be a snowbird from up North. If you have the vin you can pull a free Carfax from AAA road service at a certain tier. It’ll show it’s Reg location history.
That’s the first and only one ending in 66 I’ve ever seen. If it doesn’t work, we can make a deal to get you the 09 Tahoe 4G WiFi VCIM I just took out.
adventurenali92
Big Bear Lake, ca
Did a little swaparoo with the OnStar VCIM from the 09 Canadian Hybrid to the 11 Canadian Esky O/S VCIM. The O/S Rep confirmed my vehicle (donor vehicle) was showing on her side as an ‘11 ice white Cadillac Escalade Platinum. This is a huge score.
When using these preloved Canadian 3/4G O/S modules it’s beneficial to have a make, model and color match. The O/S VCIM is active under my name but the original truck it was born into stays the same and can’t be changed. If the truck is stolen I can call and have it shut down. When it’s recovered they’ll find a white Esky ESV Platinum. I’m sure they’ll have questions about it being a different VIN and Year though.
O/S set up my new 3/4G account to the same App I had for the 2011 Esky 2G VCIM they shut down last year. I pressed the ignition start button, held it down and 10 seconds later, Voilà! It remote starts and stops via the cell phone App.
The 07-09 trucks were never meant to have these 2010+ O/S features. The fact that GM opted to shut down their 2G O/S network that supported this cell app feature stinks. It’s even worse they never offered it to older vehicles when it’s 100% backwards compatible and plug n play as well as adding unlimited 4G WiFi service to the truck for $15 Mo.
Wait a minute…… you’re saying this onstar VCIM thing can add 4G Wi-Fi to an older truck?!?!?! Like as in I could add this to my 2006, activate onstar and have wifi in the truck?!?! :eek:
petethepug
petethepug
Michael
SoCal
Yes, it was a Canadian upgrade program for 03-14 GM full size SUV and a bunch of others. Obviously they killed the program long ago but the VCIM are slowly showing up in Canadian junkyards from early vehicles that have been totaled out but had the upgrade done at the time.
The 03-06 Yukon VCIM part # is 23230482. You'd have to go into ebay and set up an automated search for that number and when it shows available, pounce on it. Unlimited ATT wifi is $15 Mo.
adventurenali92
Big Bear Lake, ca
Thanks for the info! I’m gonna keep my eyes peeled cuz this is rad!
petethepug
petethepug
Michael
SoCal
Gas door latch time. Mine had a busted grommet. I ran into # 20912532 on Amazon for about $13 bucks shipped.
Used a specialty tool to remove it.
One minute later, good for another 15 years.
petethepug
petethepug
Michael
SoCal
Well, the eBay OEM tails arrived today. $240 for both sides to the door = score. What a cool seller. It took the sting out of me ordering the wrong rear disc brake conversion for the daughter’s 01 s10, that’s unable to be returned.
A quick note on these 12-14 Premium tinted rears. They’re exactly the same as all the others, only the lens is different. Why do they fetch a premium? I don’t know. I guess value equals demand & supply.
CMoore711
Those are a great find for $240 shipped for both passenger and drivers side! I’m having a hard time finding one side for <$300.
petethepug
petethepug
Michael
SoCal
Moving over from the center brake lamp on the roof to the full width version that spreads across the entire length of the reflector. This truck isn’t as prone to being hit as the black YXL Denali but the extra spray of LEDs on the heads up should be an even better stopping deterrent.
Got a tinted version because it looks better than the red. Eventually I’ll see if I can swap the clear, slightly tinted 12-14 Premium trim lens over the this unit to match the 12-14 tail lamps better.
The individual led technology is slowly disappearing with the newer neon look that’s still led, but has a diffusing lens or pipe type led lamp inside.
The 2015+ full length tail lamps are cool and striking but for me, only on a 2015 truck.
Tough call. The truck above is a 12-14 Premium with the OEM roof clear tinted lens. We’ll just have to see.
petethepug
petethepug
Michael
SoCal
Thanks for the heads up. I did see the OEM gently smoked / clear ones were still in stock. The only issue was that somehow, someway, someone (GM?) had found a way to lean on the guy the made the full width led 3rd conversion kits.
I needed a 12-14 Premium oem style 3rd brake lamp but there’s no one to make them light up on their full width anymore. For $175 to the door, couldn’t pass this up.
petethepug
petethepug
Michael
SoCal
It’s Christmas Eve 2024. It’s been an awesome year rolling coal 100+ octane e85 on Teslas and they can’t even tell. Good times in CA filling up this 6.2L Esky for $75 on alcohol vs $140 on 91.
Happy Holidays to all and your loved ones.
petethepug
petethepug
Michael
SoCal
Just weeks away from throwing all the aluminum front suspension parts on the 09 Escalade, then …
Crunchy sound. Walk around the truck and see that the front p/s brake disc is scorched earth. Fortunately the last front brake job was a pad slap and the rotors were OEM. Even had them turned down for reuse one more time.
I have a set of CTS-V BBK ready to be installed but must have zero down time as this vehicle is a daily and still have a back injury. I went bargain shopping on Amazon & R/A. Using R/A as my pilot I found bargain basement Raybestos discs and my preferred Bosch ceramic pads. Then I checked Amazon and their “like new”, torn up packaging special. That got me the same deal for $139 including tax & delivery in 48 hours. The Indi did me a solid and installed the boat anchors for $100.
Really thankful not to be chained down to a dealer with a new car. Having access to good, inexpensive parts on the fly rocks.
petethepug
petethepug
Michael
SoCal
I did another “like new” purchase on Amazon for a radiator. It arrived all chewed up, warped and not packaged correctly.
Looked at the full price version and it did not accept any address from CA, AZ or CO!?!?
Amazon gave me the run around and offered only to refund my money, referred me to GM for an exchange (huh?) or offer a partial refund on a broken radiator.
Amazon is looking into why their own company can not ship another radiator to me. Then I stumbled across this …
OldWYLawman
