Touch screen is black but still works . . .
Tms1989
In the last month the center touch screen has gone black for a few minutes before coming back on. Well the other day it went black and stayed that way.
I can’t quite figure out what it is. So far I have:
- Disconnected the battery to let the truck reset
- Checked the HDMI cord into the HMI
- Made sure all other connectors are tight
I don’t think it’s the HMI because the Bluetooth, radio and all other features still work. All the buttons under the screen (volume, Menu, etc) still work just fine. Even weirder is the “touch” still works where you can still change the stations by touching the screen where the preset buttons would be on the touch screen.
Any other suggestions before I have it diagnosed?
(2015 Tahoe LT)
ghazallsyria
If do you want my advice, change the wire that connects HMI and headunit .
This issue has been fixed with me .
ghazallsyria
lovelylin80
(2015 Tahoe LT)
So I had the same issue brought to gm I had to replace the screen however the new one worked but cut out again they jumped the video cable and it worked they said it was the video cord now I'm trying to find one as gm doesn't even know the part number ugh
lovelylin80
(2015 Tahoe LT)
Did you find a fix
T
Tms1989
Did you find a fix
Unfortunately not yet. The screen worked again for a short while before dying. I put a DVD on the other day and it played on the touchscreen so at this point I’m leaning towards the cord or HMI being bad. I haven’t had the time to try and play with it just yet
lovelylin80
Interesting my screen went black and would not come back on. Gm said I needed new screen... 1k later ok installed it so then it powered up and boom went blank...they jumped the screen and then said I need a new cable....however that part is discontinued and I cannot get it anywhere. Straight up loosing my mind.
scottd
