5inch rcx lift on 17s fitment?
Deityrider69
alright guys i have a 2008 tahoe 2wd im putting a 5inch rcx lift on it. my question is will i have to run spacers if so what size? rough country states online there kit is recommended for 18" or larger wheels. my wheel and tire specs are 17x9 -6mm offset 4.75 backspace on 285/70/17s. even though roughcountry states that there are many who run that lift with 17s and 33s or 35s. my only thing im trying to figure out is if they will rub on knuckle or something else. also trying to make sure wheels are even with front after lift. thank you
Trey Hardy
You’ll need atleast 1/4” spacers for the front to clear the uca on stock or no offset wheels
Trey Hardy
Ex
also if I’m not mistaken you’ll need 1.5”-2” spacers in the rear to get them even with the front because the knuckles pushes the front out more
I got 2” in the rear of mine and if I did .5” spacers up front they would be perfect
Deityrider69
Deityrider69
Ex
ok perfect thank you the rough country rep told me 2"spacers for front and back. but that didnt make sense to me since kit already pushes fronts out further
Trey Hardy
Definitely not
2” spacers in the back and 1/2” up front should be even
I say 2” because I believe you have to trim your wheel studs shorter running 1.5” spacers
Deityrider69
Deityrider69
Definitely not
ill go with that then thank you so much for the help!:cool:
Trey Hardy
Also the 5-6” is essentially the same as the 7.5” so if you wanted to run 35s/37s in the future just throw a 2” leveling kit under the strut or get some lift struts for a 7.5”
The 7.5” is just the 5-6” kit stretched out all components are the same I adjusted mine from 9” to 7.5” down to 5” on my Silverado as she went through her stages…
Deityrider69
Deityrider69
good to know thanks again im sure mine will she many stages as well lol
Deityrider69
Deityrider69
should i be running hubcentric spacers?
Deityrider69
Deityrider69
also rough country says This kit is packaged as a leveling kit—raising the front 5” and the rear 4.5” will i need to get spacer on rear to sit even and not sag?
Trey Hardy
No it should be close enough id use the 4.5” springs and if it don’t sit like you like its pretty quick and easy to install a rear coil spring spacer and there cheap on Amazon or eBay
Deityrider69
Deityrider69
thank you so much trey your a lifesaver!
Trey Hardy
No problem man let me know if you need any help!
I’ll say if you have any vibrations at high speed after the lift I’d look into the adjustable rear panhard bar (150$)
To center the rear axle and prevent binding your rear trailing arms up over bumps
If you go higher I’d also recommend the rear trailing arm drop bracket as it don’t come with the lift but can be bought directly from them.
It lowers the rear trailing arms getting them back in stock position
The RC upper control arms are strong but I personally diddnt like them
Deityrider69
Deityrider69
good to know yes if i have any more questions ill definitely let you know and ill post some before and after pics!
Dh1280
