New guy went all in on a 2015 PPV and a SSV!
jmasterchamp
Hey all,
New guy here. Might be the crazy new guy, but who knows. I went all in on a 2015 Red Tahoe SSV with 79k and a 2015 Police Chief PPV with 91k. Both my cars crapped the bed and the wife and I were in rentals. Needed something safe, easy to work on, 4 wheel drive, and that can get me 300K as I will drive it until its last days. Three kids and broke like everyone else. I just can't afford $2000 in car payments. So I bought the Red SSV for the wife and the Black PPV for me. The Red had all lights installed all functional with center console. All for sale if its legal. Switches and all. I removed the decals and my wife loves this this truck. I removed the back cage and am keeping the rubber floor cause my kids are messy and its easy to clean. Adding a third row and adding the pup console that is in the black PPV.
I also scored the 2015 Black SSV for me. Came with Carpet and the pup console. Fully loaded with interior functional police lights and sirens. All for sale if its legal. It was a former lieutenants truck. So far I'm super happy. Ran into some bad luck on jumping in without using the correct resources. I bought full leather 2016/2017 suburban front, mid, and 3rd row seats and center console setup from a demoed suburban. I assumed the seats would fit, and so far no luck with bench or 3rd row. Nothing matches up and even the base latches can't be swapped. So far mid and 3rd row out. Trying to get the console set up with the front heated seats. I haven't taken the front seats out yet but the center console does line up well. I just need to get heated seats switches set up. Happy to be here and hear your thoughts. Long time Tahoe fan.
I have a lot of questions and am willing to share the journey as I go along. I appreciate any and all help I can get! Happy new Year!
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon. You are gonna love these vehicles and have fun personalizing them.
You should start a build thread for each truck. Scroll thru the forum on the home page and do it at the section called "Under Construction".
J
jmasterchamp
Thanks for the advice. First timer for a forum or anything like this. Ill create a post for sure.
Sparksalot
Bastrop County, Texas
Hey all,
Be sure to check out the PPV subforum.
Welcome to the Forum from NH.
Very nice finds!
Marky Dissod
Needed something safe, easy to work on, 4 wheel drive, and that can get me 300K as I will drive it until its last days ... I appreciate any and all help I can get.
1a.Do NOT wait for the oil life monitor to hit 0% before changing the motor oil.
Even if you do not disable or delete v4 mode, the more often you change your oil and filter, the longer the variable mode lifters will last before they force you to replace them.
I'd suggest changing the oil and filter no later than every 4,000miles.
If the vast majority of your miles are lazy highway miles in clean air, maybe 4,500 miles?
(Along the same line of reasoning, changing the ATF and ATF filter more often than recommended by GM will help the transmission last longer too.
I'd recommend no further than every 35,000 miles, or less.)
1b. If you can find the larger oil filter for your engine, the longer one's extra filtration capacity will make longer intervals between oil changes make more sense.
2. If V4 mode has not been disabled, the best investment for the longevity of your engine AND transmission, is disabling V4 mode.
If you're sure you'll keep them forever, save up and delete V4 mode hardware when your finances are well shored and buttressed.
3. although reprogramming the ecm & tcm is not cheap, the improvements in driveability, durability, and longevity will pay off over time.
J
jmasterchamp
I'd suggest changing the oil and filter no later than every 4000miles.
If the vast majority of your miles are lazy highway miles in clean air, maybe 4500 miles?
(Along the same line of reasoning, changing the ATF and ATF filter more often than recommended by GM will help the transmission last longer too. I'd recommend no further than every 35000 miles, or less.)
1b. If you cand find the larger oil filter for your engine, the longer one's extra filtration capacity will make longer intervals betwen oil changes make more sense.
If you are sure you're gonna keep them forever, save up and delete V4 mode hardware when your finances are well shored and buttressed.
3. although reprogramming the ecm & tcm is not cheap, the improvments in drivability, durability, and longevity will pay off over time.
Thanks so much for the advice. These were a big investment for us and we want them to last forever. Very much appreciated!
Marky Dissod
Tahoe and suburban rear seats have different mounting locations if I remember correctly.
They are very different. There is so much advertising on f book market place claiming to be cross compatible.
They are definitely not from a 16/17 Suburban to a 15 Tahoe. I’ll update my build log when I start it in the center console and front seats.
Used to think that the differences between a double cab Silvierrado, a Tahoe / Yukon, and a Suburban, ALL STARTED BEHIND THE C-pillar.
IFF that had ever been true, it likely stopped being true by the time the GMT400 debuted.
(Although I still refer to Tahoes as flat-@$$'d Suburbans, or Suburbans as fat-@$$'d Tahoes.)
CMoore711
Welcome! You've come to the right place for wealth of knowledge on these SUV platforms, especially if you're a DIYer!
They are very different. There is so much advertising on f book market place claiming to be cross compatible. They are definitely not from a 16/17 Suburban to a 15 Tahoe. I’ll update my build log when I start it in the center console and front seats.
They are cross compatible with the same wheel base models. ie Tahoe, Yukon, Escalade cross compatible Suburban, Yukon XL, Escalade ESV cross compatible. There are also some slight variations in leather, some perforated, some not, also with the stitching across various models and trim levels.
J
jmasterchamp
Great to know. Thanks so much!
J
jmasterchamp
Welcome to this great forum.
Thanks so much. I have learned so much so far. I am still stoked about the PPV and will be sharing a cool build log under the under construction section. Cool community so far.
So far I’ve learned a ton about maintenance and what to look forward to as far as problems. I already started digging in a working on it.
Going to start the build post soon. Here’s one of the many photos. Loving this thing so far. Later!
Sparksalot
It’s nekkid!
The Whip
