- Joined
- Aug 2, 2018
- Posts
- 10,339
- Reaction score
- 14,988
They are on the west coast.I tried calling you and no one answered. Are you on the West coast?
I have my local torque converter rebuild them...He does a few upgrades to his stock level builds which address all the shortcomings w/the factory converters. Unfortunately, he doesn't ship those out anymore as it's been a mess getting folks to ship cores back.
We heard back from Justin and we will be able to help out. We will give you a call to discuss.I just got ahold of Black Bear. Waiting to hear back from Justin who I think is the Tuner, in regards to my issues. I want make sure 110% a tune will fix this.
Haha. Discussing this right now in my head.We heard back from Justin and we will be able to help out. We will give you a call to discuss.
Thanks for the insights. Was your original trans all stock with a BB tune?I recently had my 6L80 rebuilt to withstand my future procharger. The shop that built mine says that the torque converter slip has to be zero'd out and that lockup should be limited to 4-5-6 gear. They installed a triple disc converter and he wouldn't let me leave the shop without verifying that the TCM was properly tuned for the converter. Since I had a Blackbear tune even before my original trans blew up, I was pretty much good to go. I believe my stall is 2600-2800 and it drives completely normal, until I mash the gas pedal down!!
Yeah it was the original trans, and it had been tuned by Blackbear. It lasted 180k, and I also had a circle d converter in the original trans, just a higher stall with that one. Unfortunately I couldn't reuse the circle d because the transmission pump blew up.Thanks for the insights. Was your original trans all stock with a BB tune?
@mikeyssYeah it was the original trans, and it had been tuned by Blackbear. It lasted 180k, and I also had a circle d converter in the original trans, just a higher stall with that one. Unfortunately I couldn't reuse the circle d because the transmission pump blew up.
I never read the circle d without Blackbear tune. My issue when the original trans blew is ALL of the fluid was pouring out of the bell housing area. There were symptoms before that happened though, like shift flares and mushy shifts. It also slipped in 5th gear at times, or it felt the converter couldn't keep the lockup applied.@mikeyss
That’s unfortunate. Did you happen to ever run that Circle D converter without a Black bear tune? If so, I’m curious if you had the same issue in having with the a slight shudder and converter not locking up when it should.
Thanks!
Thank you! We will have your AutoCal shipped out on Monday. We look forward to working with you.@BlackBearPerf
Autocal has been ordered.
Glad it arrived safely and thank you! We have received your files.@BlackBearPerf
AutoCal received and tune files sent over to you. Hoping to get this driveable and seeing if the TCC improves!
Thanks!
