06 Tahoe/Issues
Kstrauss77
I have an 06 Tahoe z71. My window switches, power locks, 4x4 buttons, oil pressure, battery voltage gauge, fuel gauge, coolant temp gauge do not function/work. Checked all the fuses and relays. Before I get to deep into the issue has anyone else had this problem and what was the fix? Also where can I find good schematics? Thanks
mountie
Wondering if there was a previous owner that did any DIY electrical work around the dash? Try using a OBDII scanner for any hints?
K
Kstrauss77
It does have an aftermarket security system, remote start, and head unit. The obd2 will not connect to any of my scanners. And it never had a problem until yesterday
mountie
Your issue would drive me nuts.... I am an idiot about that sort of problem. If you have a little bit of a budget, find a local "Auto Electronics" troubleshooting shop. I wonder if the security add-on is a cause? Good luck .....
K
Kstrauss77
Yea I was either going to looking into my pcm or send it to a shop. Try and cover all my basics before
Yizzo88
