Intermittent Start - SOLVED
SnowBuck
Turn the key on. Dash lights come on. Turn to Start = nothing (no crank)! Try 5 or 6 times and maybe it'll start. Runs fine after that...but it's a crapshoot if it'll start again. May go weeks before this happens again.
Replaced: battery, Engine Control Module (programmed by Dealer), Starter Relay.
strutaeng
Dallas, Texas
Next time it happens go down there with a test light and see if you are getting power to the starter solenoid when you flip the key to crank.
A long test lead and putting the test light on your windshield is an option if you don't have a helper.
rockola1971
Indiana (formerly IL)
Could be alot of things. Bad starter, corroded or loose battery cable at either end, bad ignition switch, bad or misadjusted safety switch at tranny (Park. neutral switch). Bad ground at the firewall or engine block, this guy can cause havoc on your BCM which just so happens to give the PCM the OK to start engine AFTER your passlock system tells the BCM you aint a thief.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Last time I ran in to these symptoms was a failing ignition switch in my girls TrailBlazer, same switch by the way, and now no problems but as has been said, it could be numerous components.
SnowBuck
SnowBuck
No power to the starter, that's why I replaced the ECM and starter relay. Still intermittent start.
An updated ignition switch will have the grey covers mixed with black, instead of all black. Very hard to find a genuine GM part but are out there. I found one at ebay. It is a less than 30 minute swap out and there are some videos at you tube. I have a couple videos there showing me replacing that switch on my girls Trail Blazer. Is basically the same steps. Not very expensive and was definitely the source of her intermittent no crank problems. The updated switch is because of internal contact problems causing the intermittent no crank problems.
you did not state this in your initial post, details like that are critical to diagnosing the problem
this means you probably need to trace the problem from the ignition, replacing the ignition is cheap and easy, then if it still happens it is one less thing to check
the most common issue's are
**grounds**
starter solenoid
starter power cable/harness
ignition switch
ecm harness (corrosion/water intrusion)
then it gets harder, like broken wire in firewall, bcm harnes, etc
or like already stated something simple like a transmission position sensor, shift interlink etc (scanner would be helpfull)
if you have a tech2 or comparable high end scanner it can tell you the ignition position when the problem occurs, with the scanner on and switching the ignition positions it will tell you if it is working, if it is then you know the problem resides somewhere else or if it does not show the correct position then you know it is from ignition to bcm
I think having the ecm reprogammed was probably a waste of money as that would be a last resort
intermittent problems are simply a pain......
**grounds**
starter solenoid
ignition switch
It is like pulling teeth sometimes, getting info.
SnowBuck
SnowBuck
I think you mean the ECM (Engine Control Module) ? Replaced it. Passlock system wouldn't let it start til I had the Dealer program it. Worked fine for a month, then back to intermittent start.
SnowBuck
SnowBuck
By "no power to the starter" do you mean that the control circuit to the starter solenoid was missing the crank signal, or did you mean something else?
Starter solenoids can be intermittent.
Replaced the Starter solenoid.
rockola1971
Uhh no, not in a 2000-2006. Its called a PCM (Powertrain Control Module) which controls the engine AND the transmission. And the BCM (Body Control Module) handles mostly interior lights, passlock and what not.
afpj
As others have said, bidirectional scan tool would be quite helpful here. IIRC, cam position sensor could cause similar symptoms?
lyncht1967
as a test connect one end of a black jumper cable to batt negative and other end of black jumper cable to block somewhere and try cranking...if it starts you have a bad negative battery cable..common on these models. can do the same thing from batt pos to starter pos and try cranking..if it starts you have a bad positive battery cable. common issues on these models...i had the same issue a month ago and it was bad negative batt cable.
SnowBuck
SnowBuck
GOT IT ! But - what IS IT ?!?!? While installing a new ignition switch, found this. When holding in Start and nothing...hitting this caused it to start. Looks like some sorta starter interrupt. Taking it out = full start! Has "6900A" on it.
lyncht1967
Ahhh...yes...there's a variable isn't it. Looks like maybe an aftermarket remote start or alarm unit. Must not have been letting an ignition signal through. Great that it is out and now you're starting and running!
CrackerJack135
