Front Driveshaft bolt size
opfor2
Riverside County, CA
does anyone know what size bolts are use on the front driveshaft on a 2011 Tahoe 4x4? I need to drop the driveshaft to get to the oil cooler gasket and the prsent bolts are thrashed and I would like to replace them.
Thank you..
donjetman
11 mm is the "hex head" size, it is not the size of the bolt.
If I needed them I'd check with the dealer, drive shaft shop, or junk yard.
89Suburban
Bull in the china shop
SE PA
Thank you..
I didn't read this correctly at first, you can take a existing one to a hardware store and get the same length pitch & thread. or if you want oem or a "set" most likely you will have to order them, nobody seems to stock them.
mojoe_jojo
