Advice on Black Out of a 2023 Tahoe
a96nautique
Hi All,
New to the group. Just purchased a 2023 Tahoe Premier- white and Chrome.
Today, I replaced the Tahoe badges, from Chrome to Black. Tried to tackle the chrome emblem across the back lift gate below the window and the chrome strip on the back bumper.
Thought I could remove the plastic interior to get to the chrome emblem but need to remove the plastic part just below the window and above the license plate. Got halfway there by removing as many screws as I could only to find clips I can’t access.
Any advice would be appreciated
Dave
StephenPT
St. Helens, OR
Welcome! Dick Hannah - you must be somewhere in the PNW - hi "neighbor!"
Are you wanting to black out the wide chrome trim that has the bowtie in the middle of it? If so, use this video as a reference to see disassembly of the tailgate. It's a big job, but he goes through everything step by step.
I'm pretty sure the "Tahoe" and "Premier" logos are just held on by double stick tape.
Dome33
I purchased factory nameplates and emblems and then had the rest of the chrome pieces wrapped by a local guy. Much cheaper than buying the blacked out trim and replacing and looks just as good. Just make sure you vet the company/guy wrapping your trim to ensure they know what they are doing and doesn't take shortcuts.
thegrunter
I'm also looking to blackout wrap the chrome on mine. I'm leery if the black OEM double-bar (RST) will fit on the LS Grill. I don't want to have to buy the RST Grill too. I think the rest of the OEM RST black parts will fit the LS.
Vladimir2306
I replaced the chrome letters with black glossy ones. Everything is done very simply. The letters are cut with a fishing line. The adhesive can be cleaned with any body cleaner. Well, this is how it looks.
thegrunter
How long does wrap last before it needs to be removed and replaced? More than 5 years? Also, does wrap damage the undersurface chrome where you can't go back to shiny chrome. Like the old saying, "Once you go wrap, you don't go back"?
Vladimir2306
The chrome film does not damage) on the contrary, it preserves it)
thegrunter
How do they trim the vinyl and not cut through paint resulting is rust bubbling up years later? I only imagine an exacto knife is used to trim. I can't think of any tool that can get into creases and cut the vinyl. Am I not understanding the process? I don't think they dismantle a car and wrap and trim each part. It would be more expensive than to just buy the OEM Black parts.
Vladimir2306
The guys who glued the vinyl used a knife very similar to a medical scalpel. And yes, for pasting they disassemble the parts, in particular for pasting my roof, they removed the roof rails. I looked carefully at the place of pruning, I did not see any damage to the paint
A
a96nautique
Hi All,
DaveView attachment 406085
Results so far
Chad G 1979
What did you for your wheels? Looks sharp. I want black rims but dont want to spend tons of money to get new rims or have my ride out of service for a couple of days.
Baja_Bob
Michigan
I would like to black out the inner part of the grille, mine came with the black lettering
A
a96nautique
Thanks!
There are videos on YouTube. I aggressively sanded the clear coat which was more a thick plastic coating. I bought high temp paint from the auto parts store vs. Home Depot just in case.
I started by cleaning and tack cloth the wheels then used Spray Away window cleaner before 3 coats of primer. Lightly dust coat 1st coat, a little heavier 2nd coat and a full wet coat to finish. Lightly sanding, 1000 grit, and tack cloth between coats.
Same process for color coat. Just before putting the clear coat on, (it said Gloss) the wheels were very shiny. After the clear coat, the finish is rather a satin look. I may sand again and finish with a Gloss color coat. Probably doesn’t need a clear coat.
You’re right! Cost was under $200 for paint and supplies. New wheels would cost $3,000 plus. Took me a weekend to do them.
Go for it!
Escalade2007
