Front Mount Hitch (2" receiver) for 2021 Yukon Denali?
tagexpcom
In my previous vehicle I use the front hitch to push my trailer into a tight parking spot along side the house and I have a receiver oriented winch + portable battery so I can winch front or back.
I am hoping to continue this capability by adding a front receiver to my 2021 Yukon Denali (6.2L). Searching, I don't see availability as you do pre 2021 with fit guarantee at etrailer.com for example.
Has anyone had success installing one or customizing one to install?
TMI: Yes, I can back the trailer in if I have to, but it's difficult as it's a curved approach / tight space / involves being partly in the street with traffic so I prefer not to back in, pull forward to re-adjust, repeat, as it usually takes 5+ mins and wheel turning repositioning hurts the grass driveway whereas push is 1 min - less exposure to the street and straight in.
Thanks in advance.
Vladimir2306
Thanks in advance.
We have a blogger in Russia, he put a square under the winch in front of the Escalade. Since structurally they are the same thing, here is the video. I hope it helps)
Chud85
Hey guys, I'm new here and saw this post about the front receiver. I have a 23 Tahoe Z71 6.2L and looking to do the same thing to mine. (And yes I too can back my trailers in anywhere but the front receiver would be nice as well). Did anyone ever find anything available or will I have to fabricate my own brackets and receiver?
Thanks in advance
tagexpcom
tagexpcom
I have a guy lined up to fabricate one in the next few weeks - will report back what happens / how it looks.
Speculation.... continued to research and I see some front hitch options on etrailer.com for 2021+ Sierra's with 6.2 and wonder if the frame is similar or even the same - but not skilled/knowledgeable enough to guess if it's worth trying this.
Funny - I tried typing 'a s s e s' instead of guess and it was *'d out - keyed on a s s ?
Chud85
I did extensive research and found front towing brackets (BLUE OX BX1747) that I could possibly modify but of course the company won't sell me just the brackets and don't want any liability if I modify them. I figured I would have to enlist the help of a local company that can cut the brackets, then I would find a welder to make up the rest of a 2" receiver. If you want a link or a picture of the brackets let me know and I'll share them with you.
Thanks for the reply.
tagexpcom
tagexpcom
Yea I saw the tow hooks. And in fact, my front bumper (the rubber part) has squares that looks like you can cut them out for the tow hooks. But I need a front receiver, not tow hooks, and once I get a receiver it can double as a tow point.
Chud85
Sorry I wasn't clear about the tow bar brackets...I would use only the tow bar brackets and bolt them to the sides of the frame then build the square steel receiver off of them. Does that make more sense?
tagexpcom
tagexpcom
Ah - yes. My 'guy' is scheduled to fabricate this front receiver in the next couple of weeks. I'll get pics and post and perhaps that will help in you're planning.
But, along this line, I believe I saw a 'bolt on' front receiver for Sierra 21+ and that's back to the idea of using this Sierra hitch on a GMC Tahoe/Yukon frame... I wonder if it would work.
Chud85
I guess only time will tell haha. I look forward to seeing how you make out. Good luck !
tagexpcom
tagexpcom
Some good news to report, getting my front hitch! My custom fabrication guy just didn't have time so...
I bought a 2021 Sierra 1500 hitch from etrailer.com - https://www.etrailer.com/new_review.aspx?oid=120641424&ouid=586EB8D1-E31D-4B1C-8A2C-8D89757BA9CA - on the thought that the frame for a 2021 Yukon might be the same as a 2021 Sierra 1500 and found a local auto shop willing to try the install.
It fits good enough! Here's a pic of the drivers side frame / attach. The vertical bolt went in OK but the horizontal bolt (top right of the pic) doesn't line up so well and on the passenger side doesn't line up at all. So they're going to do a ~1" weld instead of drilling/bolting. The passenger side frame has something jutting out that get's in the way of drilling easily.
Didn't have to take off the front fender, just the mud-splash.
Side question - They said that if you take off the front, you may have to re-align the lane departure stuff?
In any case, much easier to just remove mud-guard for access.
The shop let me come down and take these pics and excited to share soonest. Will do a follow up with mud-guard back on etc when I get the rig back.
tagexpcom
tagexpcom
Final pics - the receiver 2" tube/body is ~8" off the ground - same as the metal pan plate under the engine - so no loss of ground clearance.
Ordered a 12" hitch (from pin to center of ball) to get the ball to stick out far enough for clearance around the ball without banging into the bumper chrome piece.
FYI - I use this to push our trailer around a blind curve into a narrow space between home and fence. Front push gives *precise* control + I can see as it's a left curve and makes it a sure thing I won't knock over the fence or gouge the house :)
1948Buickroadie
