iboughtatahoe23
- Joined
- Feb 17, 2023
- Posts
- 1,133
- Reaction score
- 570
So my fuse sparks for radio when ever I put it in. Which makes me think short somewhere in the harness?
Ya the radio turns off. Radio works fine as it should just the accent lighting issue. It won’t turn off with the car all the other lighting does…. Do you think that isolates my issue?Unplug the radio and put fuse in to see if it still sparks.
Also have the radio on when running, turn car off and open your door. Does the music turn off?
I am thinking it's the radio.
Could you explain what you mean more by “if it was power it would work fine”Seems like radio issue to me.
If it was power, I would think the radio would operate normally...
That's my guess anyway...
Fingers crossed! I guess I’ll try a new radio.If it was the signal to power the radio on..
The radio actually is connected to battery power, it always has power.
(From what I gather, you need a network signal to power these radio's on, won't turn on by itself connected to battery!)
So say the network signal was not turning it off, leaving it powered on, the radio should operate normally.
Radio quits playing music when you key out/open door, so you know it's getting the signal to shut off.
The spark you are getting is probably the radio drawing power for the illumination/usb where there maybe a short inside the radio...
or perhaps a chip got zapped which messed with the programming causing your lights to stay on.
Not sure what harness issue could make your radio try and eject a CD..
So that's why I think it's your radio.
Yep, United radio. I was gonna call them Monday!Do a Google search as there is an audio company that repairs GM radios.
Thankfully not draining my battery as well. I guess it’s just a cosmetic thing that bothers me.If and when you have United Radio do the repairs, make sure you get complete documentation of what problems they found and what was done to fix it.
None of this "Radio bad" and then "Radio fixed" crap.
Well I’d better get my radio fixed then. I’m in smaller town. We have a sound place but I don’t think they do oem radios. Be nice to to get it fixed locally.The lights are a draw, period. Small draw but a draw nonetheless. If the vehicle sits long enough or if the draw increase for any reason, enough power will be sapped away and the battery will not be strong enough to crank the engine.
