have all the dtc cleared just incase. I thru a belt on my c6 at the track and didn't notice till the car freaked out, said stuff on the dash like that. after putting the belt on and refilling. I borrowed a scanner and there was a few codes dealing with over heating. reduce power., ac stuff like that. I cleared them all and everything worked.
the reset ac post you probably saw was one I found searching once. my wife was driving and said she couldn't use the ac cause it just flashed at her 3 times everytime she tried to turn it on. lucky for me it worked after cycling the key off and back on. but I did search here.
the fix for most people seemed to be take the battery cables off, wait about 5 mins. and then touch the two cables to each other for a bit, that will fully drain any remaining power stored in any caps in the system. then hook them back up. I think you wait a certain amount of time, or click the key forward but don't start it for a bit? something like that. if you Google tahoe flashing ac button it comes up and directs you to posts on this site if I'm remembering correctly.
