Noisy interior
IMO, the most effective way to find and terminate unwanted noises is to get one or two friends to commit a few hours to driving around with you and locating the the source of the noises, one by one. Then, you can formulate and implement measures to reduce or eliminate them.
Jobi-Wan Kenobi
Jobi-Wan Kenobi
It seems like most of the rattling comes from the rear somewhere. When I had the trim pieces out to do the headliner the speaker for the rear drivers corner was just sitting loose in there. But it seems like there's other things too. I'm not sure yet if it's just loose trim pieces or something else.
MassHoe04
Western MA
I used to own an 05 Wrangler Rubicon. I have been desensitized to squeaks and rattles... LOL
If you had stuff out for headliner or other interior work, then there might be a trim panel clip that did not fasten as tight going in as it was originally.
Sam Harris
Once the squeaks & rattles are located, a great solution is to apply some self-adhesive felt padding to where the noise is caused. I have a bunch somewhere in my stockpile.. I’ll try to find you a link..
Something like this: Car Multipurpose Tape, Car Self Adhesive Anti Squeak Rattle Felt Automotive Wiring Harness Tape Car Accessories (32mm*15m) https://a.co/d/g6KLC1W
RST Dana
OH
Eliminate the noise or the friends?
briannorris
