A.I.R. SOLVED
Moosemoon
Not exactly sure where to post this; sorry if I created work for the moderator.
Was the secondary air injection system (A.I.R system) installed on 2001 GMC Yukon XL 2500 6.0l?
There is nothing in the engine bay where one would expect to see it and there is no fuse in it’s slot in the fuse box. BUT the fuse slot looks clean. So I’m curious as to whether it is supposed to be there and got removed and not reinstalled or was never there?
Thanks
rockola1971
Indiana (formerly IL)
Thanks
Look at the emmission label under the hood on the upper radiator core support. It will tell you.
Moosemoon
Moosemoon
Thank you. I do have the EFN number and what I can read of it (the guy who worked on the car used brake cleaner on everything and almost obliterated the tag) it complied with Calif. emissions which would mean it was there at some point but isn’t now. Correct?
Or did I look at the wrong thing?
thanks again
Moosemoon
Moosemoon
thanks again
Moosemoon
Moosemoon
It appears despite evidence to the contrary, this Yukon did not come with the secondary air system
Dh1280
