Sparksalot
Bastrop County, Texas
It started as an oil change and annual inspection. Then I probably need the coolant replaced.
so now the front and rear differentials and tcase are serviced. Coolant replaced. fuel injectors cleaned. And the front sway bar bushings got scared and ran away sometime in the last couple of months.
with the new brakes when I bought it and the transmission fluid service a few months ago, the rig ought to have a pretty good baseline for service.
Sparksalot
Fondled the airbags, getting ready for the next step.
tsuintx
DFW
First oil change on my wife's new-to-her Suburban. Catch can was surprisingly full and had crap that had wet almost peanut butter like consistency at the bottom. The can is much smaller than the Elite Engineering can I had in the old one, so I need to remember to check it a bit more often. All that crap has collected in about 3500 miles.
Also installed a Fumoto valve to make future oil changes a breeze.
tsuintx
DFW
Finally also got around to do the data logging for my DiabLew tune on Sunday. Lew did great job turning the files around in less than 24 hours, so loaded them yesterday.
Such a big difference in the way the truck behaves! Money well spent once again.
RST Dana
OH
What year is your ride?
Thrust
ICT
Added a 20" spare tire so it will work with the front Brembos. And yes a 275/55/R20 will fit in place of the 265/70/R17. You just have to make sure you move it so it doesn't catch on the heat shield on the way up.
tsuintx
DFW
BTW, forgot to add that since Lew raised the idle rpm, the slight vibration the truck had at idle when in gear is also gone. At just over 100K it does need plugs, too, and those are on the to-do-list. And of course I will also get a set of new wires since I don't think I've ever been able to get all wires out without breaking at least one.
SpyShops212
Does it show more tire when looking at it from behind vs the factory spare?
a1parrothead
