What's Wrong With Your Yukon/Tahoe Today? ...And How Long Has This Been Happening?
Updated it the same night, didn't help.
Might want to try logging out, disconnect vehicle battery ground, leave disconnected for a couple minutes and then try again
stupid cars running on software made for phones now, every once in a while you gotta reset it for a multitude of issue's
otherwise some spotify related fixes here
Saltydog
So I just noticed the rear suspension is making crunching noise when going over speed bumps. Very annoying, not a hug deal but on a rig this expensive that should not be an issue.
JGinLA
Law Enforcement
Lower Alabama
You're better than Google.
JGinLA
Law Enforcement
Lower Alabama
I think I cleared the cache that same night but even if I did the problem remained. Here's what I did today, not sure what made the difference. Hooked up battery maintainer so I didn't have to run engine. Told Google assistant to play Procol Harum, bar appeared like it was loading. Assistant says "Something went wrong." Then I tapped album cover. Song played fine and started another song. Told assistant to play another band and she did it correctly. Much thanks.
I think I cleared the cache that same night but even I did the problem remained. Here's what I did today, not sure what made the difference. Hooked up battery maintainer so I didn't have to run engine. Told Google assistant to play Procol Harum, bar appeared like it was loading. Assistant says "Something went wrong." Then I tapped album cover. Song played fine and started another song. Told assistant to play another band and she did it correctly. Much thanks.
updates tend to break things sometimes that otherwise worked fine previously or it goes other way around and updates fix things lol it's a never ending cycle and now that they are doing it to cars much more frequent than they ever have in the past expect more headaches in the future.
first it was mechanical part issue's and now it is both software and mechanical combined. troubleshooting these things is going to be a nightmare down the road when the modules start getting goofy and only work part time or boot and freeze or do other erratic behavior. most modern phones barely make it 2-3 years before they are simply either just flat out outdated or the internals start to fail, I don't really see the new vehicle electronics being that much better but time will tell.
Emily does a pretty good cover of "Whiter Shade of Pale."
Fast_AT4
RWM +1
SW Florida
Notified about an updated. Opted to do it in my driveway vs out and about. It failed to complete and then notified again about the update.
..round and round -Ratt
Saltydog
Mine did the same thing, but then the next day it said no update needed? So I guess it is good?
damnit_bobby
2021 Tahoe LT, low mileage and new to us as of January.
Been an amazing ride so far and love this truck. With that being said I have an annoying squeak coming from the 2nd row seatbelt. It comes and goes (if the seatbelt is buckled in it goes away) but if it's not bucked in, and we hit even a slight bump, it's making a squeak.
If I push in the area on the trim where the seatbelt retracts into the squeak goes away. Leads me to believe it's something with the pully mechanism behind the trim (think it would be the "C" Pillar).
Stbentoak
Same here, I have a rattle below the wireless charger area that only rattles at Idle when we stop at a light etc. Could be under the vehicle but the dealership "Said" they couldn't find it. Irritating, but learned to live with it. Of course in park when I try to find it.. it won't rattle !
StephenPT
St. Helens, OR
Might be from under the vehicle - double check that you have all your heat shield retainers and that they are the updated "blue" retainer.
damnit_bobby
For what it's worth in my wife's Sante Fe we had this annoying rattle that only occured at idle too. Went away as soon as the RPMs started increasing.
Turned out it was a loose heat shield or something like that. Had the mechanic I trust give it a one over and he fixed it (tightened it?) for no charge during an oil change.
Stbentoak
I took this TSB to my local GMC dealer this morning and they ordered a complete set of these retainer nuts and said he will give it a try. That’s better than I expected. We’ll see if that’s the answer. Thanks for giving me this tip.
flajax
Dashboard lit up like a christmas tree, gave the brake error - speed limited, became undrivable. It's my wife's car, so I had her park it and I called the dealer... "oh we are booked solid, we can get you in to take a look at it in three weeks, and no, we can't give you a loaner"
I politely lost my shit.
Did some research here, and limped the damn thing home and slapped it on the battery charger and that took care of it, but now the battery won't charge or hold a charge. I'm starting to wonder if the last software update caused an issue. I'm still going to have it towed to the dealer and let them F with it.
ProfeZZor X
ProfeZZor X
High Country
My dash went black twice since I've owned it for one year. It was quickly resolved by restarting the vehicle, so it wasn't a big deal. Knock on wood, I haven't had any issues with my vehicle other than a visibly crooked AT4 logo on the passenger side door. The dealership that I bought it from didn't install it with care, so when my vehicle was shipped to me, I had my local dealer order more and install them, since it was still under warranty.
Stbentoak
I took it in today and they did install these upgraded heat shield nuts....but... The tech used a stethoscope and actually discovered my specific rattle was coming from a wiring harness in the tunnel between the seats that either became unfastened or was never fastened at assy to an isolation clip and was rattling against the hard plastic shell.
So far my dealer away from home has done and fixed anything necessary under warranty and done it with a smile. I just may be lucky....
ProfeZZor X
ProfeZZor X
High Country
For the last few days I've been driving around locally, I noticed my steering feels a little peculiar. It's almost like it does a slight crab walk. It's not totally obvious, but you know when you have that instinct about something off when you're daily driving, and that one "thing" you feel uneasy about makes you question if things are okay or if it's a problem arising.
EDIT: I drove for around 350 miles yesterday and it didn't seem to have that unusual "wobble", so maybe it's all in my head. One thing I did notice is that when I hit the throttle hard for instant acceleration, it does seem shift during that initial throttle.
Escalade2007
