2022 Tahoe: Rear-end collision now issues with liftgate window. Anyone got a '22 to help me compare?
tahoe81
After being rear-ended, I've had my vehicle in to fixed because a handful of things were done wrong or sloppy. I got it back today and the back liftgate window still isn't right I don't think. The collision center tells me they adjusted it but it still isn't right and it may be worse now than before I took it back to them for the same issue. I have to really forcefully close the window or else it just bounces back open. Also, the window seems loose in that as it's opening, it will bounce a bit at the top and you can hear a slight rattle like it's just not quite put together. Both videos below:
Can someone else with a 2022 Tahoe confirm that this is in fact NOT how your window functions and maybe even post a video so I can have proof that it's not correct?
DuraYuk
Did the rear end collision ruin the rear door/hatch ? Or just the bumper ? Looks like the dampers are just really strong and new.
StephenPT
St. Helens, OR
All seems normal. The bounce is caused by the gas struts. Usually a dab of oil on the chrome rod near the seal will smooth it out.
The glass hatch doesn’t close super easy. You need to give it a firm push with the palm of your hand where it latches.
T
tahoe81
Yeah the liftgate was replaced, but as far as I'm aware, the glass was not. The damage was all lower on the lift gate just above the bumper. I believe they re-used the glass.
Well dang... I sure don't remember the glass being that hard to close when I bought it in April. But I've been wrong before.
I'll try the dab of oil I suppose and see what happens.
Thanks
Blackcar
Thanks
There is probably adjustment on latch that window closes on.Just have to make sure window seals good so no leaks. Good luck.
Bkihum
Champion Ohio
Should absolutely have a better close than what you show in the video.Mine is 22 Yukon from same plant and it is effortless to close
T
tahoe81
Is there any way you could take a video similar to mine and upload to IMGUR to share it with me? At this point, the collision center won't do anything further to "fix" the issue because in their eyes, it's fixed. I'd love to be able to show a video of proper functionality.
I guess I could always go to a different dealer and find the same model, but that's kind of a pain and I hate to take a sales person away from making money just because I'm comparing functionality.
Blackcar
Could get with salesperson you purchased from they are still responsible for your satisfaction.
StephenPT
St. Helens, OR
A good salesmans should know that any interaction with a person on their lot could result in a sale or future sale. Just because you're there kicking the tires and comparing functionality doesn't mean that you're wasting their time. They should be super helpful to you and leave an impression on you that while they know you're not buying today - maybe you will in the future. Or maybe you have a friend or family member looking for a car and you say "You know what, I had this super helpful salesman at XYZ dealership that gave me the time of day even though I was just there comparing functionality to my current rig."
I know there's plenty of people in sales that aren't like this, but a good one will take care of any person on their lot for any reason knowing that doing so might result in a future sale.
BlaineBug
Clown World
My 19 has to be slammed pretty firmly too - always makes me nervous to do that to a frameless window. I don't use the tailgate window much at all as a result.
BlaineBug
Clown World
I'll elaborate, I wish the window didn't open at all. Having that one central latch seems like a serious security weak point too.
WalleyeMikeIII
Sunny and Snowy Minnesota
I have always loved that the rear window opens. You can load significantly more cargo that way...and often if I have only one item to put in the back, I'll use the window vs. the liftgate. That said, I am 6'4", and have long arms. Wouldn't work for a person shorter in stature. As for the security, whether it be a latch or just a pane of glass, the security risk is the same, you will have to shatter the glass before you get that latch open...crook just going to use a window breaker either way.
BlaineBug
Clown World
I wonder if my window shattering concerns are valid. I could see use on our recent road trip where I had a loaded largo basket in the rear that prevented tailgate from opening. But I refused to use the window so far away from home!
WalleyeMikeIII
It is pretty unlikely you would break it by using it as intended. You might break it if you closed it on to something, etc...but it is a pretty strong piece of tempered glass. I used the one on my 2013 several times a week for the entire 9 years I owned it. Just make sure when you close it, you are closing it "at the latch" by using that area as the push area. Never heard of anyone breaking this by using it as intended.
Hodmjstone
