Can't Figure Out How To Program New Key Fob 2013 Tahoe LS
Just00Jake
I have the year right on the middle where they went from the "hold the drivers door unlock button" and it being on my information center. I've tried the old method that worked on my 2005 but it didn't work and the is nothing about programming or adding a key fob in my information center. Any ideas would be greatly appreciated. I do not have remote start.
Fubar0715
Scott
Southern New Hampshire
Someone may correct me on the year but I believe that 2010 or 2011, GM changed to where you need a Tech 2 or have a locksmith/stealership program fobs. My 2013 required a Tech2 bi-directional tool. There are a number of members across the country who have them and would recommend looking into one if you plan to keep you Tahoe long term.
J
Just00Jake
Someone may correct me on the year but I believe that 2010 or 2011, GM changed to where you need a Tech 2 or have a locksmith/stealership program fobs. My 2013 required a Tech2 bi-directional tool. There are a number of members across the country who have them and would recommend looking into one if you plan to keep you Tahoe long term what
What exactly does the top accomplish if it's not a ticket science equation? Lol. So is this something an OBD2 could do it an I in the wrong line of thought?
Fubar0715
Scott
"What exactly does the top accomplish if it's not a ticket science equation? Lol." Not sure exactly what you are asking here but I was hoping someone could definitely say what year that changed. The Tech2 connects via OBD port but has the ability to "talk" to modules when programing is needed.
petethepug
Michael
SoCal
After 2010 GM removed the ability to add new keys and program the remotes via the dash controls. You might think that sucks but you did get redesigned door mech, double layer glass in the D/P side windows just like the windshield and a steering wheel lock.
There’s a product call AutoSync worth it’s weight in gold that’ll allow you to do the programming from in the truck. All the other features are bomb digidy.
Foggy
KS
That autosynch device looks pretty cool... I use my Diablosport tuner as my "Monitor" right
now as I'm tuned with HPT....
Getting actual numbers on ECT etc would be awsome and I could take off the
Diablo from my dash
petethepug
Michael
SoCal
Careful to hide the Diablo if you don’t have a trunk monkey installed. I’m still waking up a night paranoid I left the truck unlocked since my tech2 was swiped.
AutoSync reprograms the fobs. Not sure if the keys can still be programmed by the truck after 2011 though or if the A/S can do the key too.
St. Louis
Pretty sure a new chip key (transponder) can still be programmed as long as you have one that currently works, without anything special like a Tech2 or AutoSync.
petethepug
Michael
SoCal
OK, got the facts ...
* 2011+ vehicles need specialist tool, autosynch or locksmith to add another remote fob.
* All 07-14 vehicles can add another key that has the (diode transponder) molded into the plastic head. Directions below ..
St. Louis
I've seen Dorman has a kit that includes one or two key fobs and an OBD dongle that plugs into the port and puts it into key fob learn mode, but is only good for like 2 uses or something.
t_bergman
Chicago
I'm guessing that AutoSync needs to stay in the OBDII port?
CLSVT
2013 Tahoe LTZ Key FOB Info:
I recently watched a YouTube video where you can program a newly purchased FOB using the buttons on the dash. Step thru your dash buttons to see if the dash LED readout provides the programing function. Apparently, some older Tahoe's allow you to program the FOB this way, others do not. My 2013 did not.
I ordered a new FOD from Amazon (Brand name: Dorman 99156 Keyless Entry Remote 6 Button). Comes with the programming device that plugs into the OB2 outlet under the dash. Cost $63. Looks simple. It will be delivered tomorrow. I'll let you know.
UPDATE:
I received the Dorman 99156 Keyless Entry Remote 6 Button (FOB replacement kit) I ordered from Amazon. It included a new FOB and the FOB programming device that plugs into the OB2 outlet. It was very easy to program the FOB and the FOB works perfectly.
One Note-I bought this so that I would have an extra FOB, so if you have existing FOB(s), you must re-program all of them them at the same time and using the same method as you programmed the new FOB.
petethepug
Michael
SoCal
Can the Dorman dongle be used more than once after it’s done its programming?
petethepug
Michael
SoCal
That’s cool. I was expecting just one. Can’t wait for someone to hack it to unlimited and continually resell it to the next guy.
ECaseyP
I know this is an older thread, but I wonder if this is a good option for key fob programming.
Edit: Nevermind I remembered I have a buddy at a local GMC dealership. I went over there at lunch and he programmed the key fobs I ordered for me. He said $20 but I gave him $50. It only took him a few minutes to get two of them programmed.
justafarmer
