Steering shaft removal
dkad260
I'm replacing my LH engine mount, and I can't see how to remove this shaft.
Does the upper portion slide into the firewall, or do I need to remove the lower bolt at the steering rack under the boot and remove as a whole unit?
I do have the steering wheel secured.
89Suburban
Bull in the china shop
SE PA
Yes, if the steering wheel is straight there is a bolt pointing straight forward under that boot. Here is a vid. I just had mine out to replace that boot.
Thank you for the video. Very much appreciated. This item is on my to do list.
D
dkad260
Thanks. Late reply but that helped.
Definitely a more cramped area with a front diff in the way, but task complete.
The RH side looks like more of a pain but the LH side was in dire need of replacement.
SDHanz
