knock sensor selection
shegarty
Hey folks - I'm tracking down a persistent misfire (which has grown more frequent with time) in my 04 Burb which only seems to occur when in tow/haul mode, even when not pulling anything. Live data shows misfire on 1 & 6 that trigger the CEL with a very small number of misfires logged in the same two locations when not in tow/haul mode. With the help of members here I have tested and eliminated almost everything short of an intake/vacuum leak (fuel pressure, injector pulse duration, spark/coil). As a result, I am preparing to replace the intake manifold gaskets once it warms up a bit here. I am thinking that I should also replace the knock sensors while I am in there. Any recommendations on brand? From what I have read some of the generic replacements (Dorman etc) can cause issues - don't want to have to take the whole intake apart again.
As an aside, I haven't been able to do a cam relearn because my VCXNano can't seem to maintain a connection during the testing procedure ... not sure what's going on there.
S33k3r
Dallas, Texas
Sounds like your plastic intake is cracked.
mattbta
Frisco, TX
Mine seems to "lose communications with vehicle" quite a bit, too. Tried various updates/firmwares and it seems to do it randomly no matter. Even trying to go in and test the e-fan relays it will crap out.
Let us know if you figure anything out there.
Can't remember if i tried win7 but current setup is
Windows 10 x64
JRE 8 x32
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Knock sensors
Gm#12589867 $122.66 each
agmanw8n
