Philpug
- Joined
- Dec 29, 2020
- Posts
- 221
- Reaction score
- 144
If I am using a remote start, chances are it is damn cold out ..why does not the heat come on HIGH, seat heaters activated and heated steering wheel all come on?
I tried this, mine is set to “on” but it still doesn’t turn on with the remote start.. odd.The riddle can be solved in your vehicle settings menu…
there is a setting in the custom vehicle adjustments you have to set to enable that function, you have to do it thru the radio, at least on mine you doIf I am using a remote start, chances are it is damn cold out ..why does not the heat come on HIGH, seat heaters activated and heated steering wheel all come on?
Because it is luxury.... can those lexus owners if they would like the same to occur in their rides?If I am using a remote start, chances are it is damn cold out ..why does not the heat come on HIGH, seat heaters activated and heated steering wheel all come on?
Mine is 12 model... I just place the auto function on the climate setti and it all comes on with the remoteBecause it is luxury.... can those lexus owners if they would like the same to occur in their rides?
