JPVortex
Hello, just tonight while taking pictures of my Tahoe I noticed this ticking it's making. It's worrying me a bit, but I don't think it's rod knock at all. It almost sounds like it could be an exhaust manifold leak, or at worst a lifter problem. The sound is only heard at idle and as soon as I rev the truck at all it cannot be heard anymore.
Here's the videos of idle and while revving it(excuse the mess of pulley noise, they're worn out and are overdue for replacement)
Idle video:
Revving video:
Thanks!
Scottydoggs
NJ
make sure you can see all the exhaust manifold bolts are in place. the back one and front one like to come out or they rust off.
JPVortex
JPVortex
To me, the clear engine miss would worry me more.
I dont really think it's missing much, it has good power and runs fine, it doesnt feel very shaky or anything to me, haven't had any misfire codes either.
The pulleys are very worn and do make some weird sounds.
Now with that being said I do notice the truck idles low at 500rpm and there is almost a little stumble only at idle here and there but I dont really see a clear misfire constantly.
GMT800 2005 Tahoe Z71
Navy Supporting Member
When you check exhaust manifold bolts, put fingers on and see if the broken part is just laying in the hole or even put a wrench on it and see if turns like is broken already.
JPVortex
JPVortex
Sounds good, I'm just scared if it backed out a bit and I go to tighten it's going to break on me.
Also from my video, do you think the engine is missing? If you agree it is I may look deeper into that.
SnowDrifter
Sasquatch Country
Pop off the beauty cover on top of your intake
Unplug the evap purge solenoid on the top-front of the intake manifold. Is the noise still present?
JPVortex
JPVortex
Heres an update video. Truck is definitely idling quite rough and it through a cel which I'll get the code for soon. I'm starting to suspect a lifter issue
JPVortex
JPVortex
Its throwing a code for a misfire P0300, and this only happens after I start hearing this tick
Not a good sign to me
JPVortex
JPVortex
Problem found lol! One of the new spark plug wires I installed came loose all the way in the back on the drivers side, which was causing a blatant misfire and the ticking sound was the spark from the wire jumping to the manifold
JPVortex
JPVortex
Told ya it was a misfire! Glad you got it solved, and it was an easy.. AND FREE.. fix!
You sure did call it! Thanks for the help and I'm very glad it was such an easy fix and that it didnt cost me anything! :)
JPVortex
JPVortex
Heres another little update. Its idling better than before but I still feel like theres a miss in there. It's hard to tell honestly with the pulley sounds, as that's what I might be picking up on. It is not throwing a code anymore.
I'm hearing what almost sounds like a slight air hiss from that bank near the intake. Are my intake gaskets possibly going bad maybe?
Scottydoggs
NJ
you can spray brake cleaner around the vac lines and manifold gasket area. if the idle changes you found a leak area. flammable brake cleaner will make the idle jump up. non flammable will make it bog.
JPVortex
JPVortex
May have a fouled plug from when the wire was off. Depends on how long off.
Ive been hearing the spark sound since yesterday so 24hours probably, i'll take the plug out in the morning and check it out. I think that pulley noise may be some of the noise too.
JPVortex
JPVortex
The engine does totally fine under load, it just seems to have a slight stumble at idle here and there, and to be honest I feel it may have been doing this for a while, so I may not worry too much about it, I'll look into my vacuum lines, I may clean the MAF and TB and check that plug.
CWool
