‘07 Denali XL, should I invest?
RyanXL
Brand New to the forum hoping to learn a lot about the Denali XL I recently got myself into.
The body is in fair shape with rust I can get fixed myself. Interior is very good for its age, just dirty and I’m working on cleaning it.
It seems to run and drive fine. Seems strong but has a slight misfire on #4. I haven’t taken it too far due to that and the leaking radiator. Tires are very good.
It’s got high mileage but I got a CARFAX on it and it seemed to be taken care of, seeing the local dealer several times for service at intervals. They aren’t specific but some visits include transmission services, tune-ups, brakes and oil changes. It’s got things here and there that it still needs to make it better.
Here’s my question, I’m turning to you guys for advice.
Before I continue to invest, I’d like to know if you all think I should be worried about the mileage on it. I got this as a family hauler for a couple trips when we need it to avoid having to rent a car.
It needs brakes and a radiator to start and I’ve got those on standby just trying to get some time to get them put on.
Would you continue to invest and care for this ol’ girl and get her back on the road or would this mileage concern you enough to say forget it and get out of it?
Welcome to the Forum from NH.
Pics of the truck, please.
I'd get the engine checked out and see if the misfire on #4 is a minor issue or indicative of a major issue. How does the transmission feel when working through the gears?
Fubar0715
Scott
Southern New Hampshire
You don't say what year, engine (probably 6.2l), or the mileage. FWIW, this is my 2nd Tahoe which I tend to own for a very long time, and they will last if you put in the time and effort to keep them in good shape. They are comfortable cruisers, can tow, haul, and just out right be a livable truck if you understand what it is you have. Will it get you a lotta miles per gallon to drive, hell no, but are nice on a road trip..
Tell us more about the vehicle details and pics!
B-train
Personally I would walk away from it. Rust, repairs, leaks, misfire, brakes, etc. You are looking at a money pit that will keep begging for more. Take the 5 to 10K you might have to invest to keep er movin and throw that at a cleaner, lower mileage unit from somewhere down south or out west.
I was a mechanic for too many years in the midwest and I know that rust is a cancer you can't cure or get away from......it affects the whole vehicle in different ways. I've been buying from Southern and western states for 11 years now and have zero regrets. You can still get the same thing you have, just in usable condition that warrants a small investment here and there to keep it going.
if maintained you should be fine, high mileage just means solid motor and usually at worst you might get some oil consumption, expect the usual stuff transmission, hubs, hoses. oil leaks.
Well, you bought it. It's a platform that you can either discard for an unknown quantity or make regular repairs to this one regardless of cost.
At that age the transmission and transfer case may have already been replaced. The engine may soon need new valve springs and the heads rebuilt.
Geotrash
Dave
Richmond, VA
I don't think we have enough information to make that call for you and what I would want to know to answer it would likely feel intrusive for me to ask, such as financial situation, how much you paid, etc. But here's how I would think about it if I were in your shoes.
You can buy a dry country '07 with 200K in good mechanical condition for less than $10K if you're willing to go to someplace like Arizona, Nevada or New Mexico and drive it home. Probably closer to $8500. So there's that. I paid $10K for my 2007 with 196K on it at the time, almost 4 years ago now. No rust whatsoever and it's still pristine underneath.
Rust on the body tells me that you will soon have other costs to deal with, like brake lines, a rusted fuel pump mounting plate that leaks fumes, rear air shocks and compressor, etc etc. You will likely have to do a bunch of other things to get it into shape if they haven't been done, such as coolant tees at the firewall, transmission torque converter to prevent transmission failure if it hasn't already been done, front diff mounting brackets, motor mounts, etc etc, ad nauseam. If you do all of this work yourself, you're probably looking at $3-5K in parts alone spread over a few years to get it taken care of, but then you will still have rust coming back.
Net/net, I personally wouldn't be willing to invest my time and money in a vehicle that is already showing significant signs of cancer. But if I literally had no other option and it's all I had with no money to buy something different, I would slowly grind through all of the repairs on a schedule over the next few years, setting aside a budget of $1-2K in parts per year until I was finished. It can absolutely be done, but there are better paths to getting to a reliable, clean '07 in my opinion.
RyanXL
RyanXL
Going to get the cyl 4 issue looked at soon.
Goes though the gears just fine. Occasionally I’ll get a harsh downshift but that’s few and far between. Pics below. I’ve just started getting her cleaned up.
RyanXL
RyanXL
No problem, I’m okay with answering any questions.
I have room to fix this up and make it safe. I paid $2200 for it. I thought it was a good deal on getting the opportunity to enjoy a big comfy powerful V8 for however long she holds on.
What I’m worried about is the possibility of it abruptly collapsing while on the road. I don’t mind she’s old or has high mileage. If she will warn me when she’s got no more life left I’m okay.
RyanXL
RyanXL
RyanXL
RyanXL
Thank you for your feedback. I appreciate it. I live up North so not a lot of minimal rust older vehicles to choose from so a friend of mine and I can drive can take care of the rust. I figured brakes and some other things are normal repairs when purchasing a used vehicle. But, I see what you are saying about the potential other issues.
RyanXL
RyanXL
Yes. I did buy. I was just thinking whether based on the pics in an above reply and how much I paid for it, would you consider continuing to work on it, making it safer?
I'm of mind to keep fixing it up since rust repairs do not bother you.
Your truck does not have a AFM, or 4 cylinder mode.
RyanXL
RyanXL
It’s a 2007 Yukon Denali XL. 6.2L. Mileage is around 280k. I’ll put some of the pics from above in this reply.
Kledford79
I just bought an 07 Yukon XL Denali, 260k miles. Beautiful, been well cared for, 1 owner. New tires. It has Low oil pressure, noisy lifter sometimes, leaks oil badly. I paid 2k. No rust what so ever, I'm gonna fix it, possibly replace the 6.2 this spring, I plan to keep this one forever.
Geotrash
Dave
Richmond, VA
Looks like there’s still a lot of life left in it. Congrats on the purchase and stick around - lots of good folks here to help you get through the repairs and upgrades.
One thing I do recommend is running premium fuel in it. Lots of 6.2s out there would still be on the road if their owners had stayed with premium. Check out the YouTube channel called I do Cars sometime for lots of examples of 6.2s with cracked pistons and worse from cheap gas.
m1dn
Bought similar one in September as something id like to learn on while doing majority of repairs myself, have a 2nd car being brand new to make sure I’m never stranded.
However the 6.2, comfort and size of XL Denali is so superb to even new cars that i just can’t stop driving it as my daily and even my wife started saying we should take Yukon whenever we go for longer trips lol.
( My 2nd car is Kia Telluride )
I also quickly learned that parts are not too expensive on it and there are plenty of used engines and parts around.
Working on that truck/engine is pure satisfaction, everything is fairly accessible and doable ( looking at you, blue badge.. )
It might end up being money pit, but you might end up loving it and won’t mind throwing money at it lol.
petethepug
Michael
SoCal
Nice job on that truck for $2.2k. The injectors should have been replaced at 100k as general maint. That will smooth the idle. I’ve heard good feedback on Duralast Gold and the price is right. You’ve got one of the longest lasting platforms and motor that is not strained to power it.
Invest in a Tech2 or similar to have full access to many pleasant conversations with your truck. Add in a 09 OnStar module to give you factory BT controlled through the steering wheel. It’ll be the best $50-$75 factory upgrade you can get.
We sold our 08 YXL Denali for $12.5k almost 3 Yr ago w/ 130k. They’re sought after and reliable. Consider changing out the carbon filled Evap canister ($95) ASAP as they leak carbon pellets into the lines and pump creating a completely avoidable $1.5k repair to go through, clean and replace items.
Enjoy the ride
Hodmjstone
