24" rubbing bad in rear.. help
ttownhitta
New Orleans(westbank), Louisiana
I just got a set of 24" rims, 305/35/24s, the front two rub which isnt anything i can fix but the rear two are rubbing up against my rear shock and on the plastic bad, my right rear tire is wore down where it rubs and the tire loses alot of air from it, my friends have 26s on tahoes, 24 and 26s on sierras and i always see 24s on yukon and no one has the same problem as me, i have a 2004 yukon, and i dont know to much about what options i have availible, can someone please help me out, i dont want to have to lose the 24s and put 22s on
ttownhitta
ttownhitta
thanks for the welcome, and im new to this, im more involved with audio rather then knowing what goes on outsidee my truck, i dont know what the offset is? i had stock rims, then a set of 20" rims and now i got the 24's, how do i figure out what the offset is?
macky
offset should be stamped on the back of the face of the rim somewhere. i think if the offset is too high you can just use a spacer, just have to make sure your studs still long enough to hold the wheel on. a skinnier tire may help some too i think.
clean454
uhhh how bad is it rubbing
can u just trim up the plastic?
how bad is it rubbn the shock?
Fauxnali
Gold Member
Edmonton Alberta Canada
Aw, thats to bad man, yeah, i would say it's definitly the offset. The tire shop you bought them from should have set you up correctly see if you can go back to them and get you a set with the correct offset.
Welcome to the site man.
ttownhitta
ttownhitta
yea i have been told to get spacers, but im just worried the studs wont be long enough with the spacers on, and to the other people, i didnt go to a tire shop to get them to put em on, i bought the rims and tires used and put them on myself, and as for how bad is it rubbing? its not just the plastic, i can cut the plastic but its rubbing hard onto the rear shocks and its just wearing down my tire so much that its causing it to leak pretty quick, i got 2 15's kicker l7 in the back in a probass box, i mean because of the box the truck is sitting level but that wouldnt have anything to do with the rubbing would it?
BOSS
The People's A D M I N
Dallas
WARNING!!! Don't ride on them. They may explode on you.
Eh not sure that's a great piece of advice there..
I would guess based on your description so far that if you are rubbing on the shock, your lowering kit installer didn't put the shock bolts in right. A well known trick is to turn them inside so the thread points inward.
But these are guesses...without pictures thats all they'll be.
Take at least 3 photos:
-from behind the truck down the side so we can see the wheel to fender
-from behind and underneath, so we can see the shocks
-from one side, underneath, take a picture of the other side
B
CIATAHOE
Orange County, CA
We do 24's and 26's a lot and the rear always rub on the inner plastic, but never the shock itself. Sounds like you have the wrong offset. I have done 5mm custom made spacers before and it helped with no issues on the lug grabbing threads. You need to find out what off set you have. I do have a set up custom spacers for tahoe lug pattern 5mm at the shop if you are interested, but I need to know the off set first to determine if that will fix your problem.
BOSS
Dallas
Alot of times the offset is engraved on the back of the wheel.
B
CKendrick
