OTA Update on 2021 Yukon Denali seems to have bricked my truck
jimmybeers
A couple days ago I received an OTA update for my 2021 Yukon Denali. The next day I did a quick start to move the truck into the driveway. It didn't start the first try, had to give it a second push which never has happened. I later got a service now diagnostic email about the airbag system needing immediate service. The day after that, the truck would not start at all and I was getting a low battery alert on the dash along with a bunch of other error messages.
I had AAA come out and jump the car, it was able to start (needed more than the 1200 amp portable jumper he had) and I thought I was good to go. I get in the truck and I can't get it out of park any longer, like the emergency brake is locked. I can shift to D and N but it doesn't go anywhere. The parking light is flashing and now the check engine light is on.
I'm waiting for roadside assistance for a tow to the dealer now, but was curious if this sounded familiar to anyone?
I'm speculating that the battery was drained mid update and something got corrupted during the software update. Everything was completely fine before the update.
J
jimmybeers
one interesting update is road assistance came to tow the car to the dealer and he was able to get it the parking brake off by disconnecting the battery for 5 minutes to get the computer system to reboot. After that I was able to drive it to the dealer. He also did me a solid and followed me just in case.
WalleyeMikeIII
Sunny and Snowy Minnesota
There is a 10mm wrench (negative battery terminal size) in the back of mine with the spare tire tools.
J Robinson
Ok, I have been a member of this forum for the last several years, I never know at this point, but anyway, just did my OTA on my 2021 GMC Yukon XL AT4 (5.3), The screen request told me to do several things before the upgrade and also the upgrade may take as much as 60 mins, so I started my upgrade at my house and requested 'Alexa' to start a timer in the house for 30 mins. Went back out after 35/40 mins. truck started right up without issue, now I have NOT taken it out for a drive yet. Does anybody know what updates they are giving us, I know it stated if I DIDN'T allow the OTA upgrade to take place I would NOT be able to get upgrades in future this way. I wanted to add a pic on my ride here, but ihave unable to locate the jpg :(
J
jimmybeers
UPDATE: the dealer inspected and cleared all the engine codes. They're best guess is my battery has been slow failing for a while. It only will take half the charge it's supposed to. They replaced the battery and everything seems to be good to go again, no errors/issues.
So perhaps it was too low to complete the OTA update, stalled halfway through and got the system in a bad state which caused the other issues.
GM should just include a 10mm in the glove box marked "reset tool" because your going to need it
your driving around in a 4 wheeled computer with software that isn't quite right yet with no redundancy other than if you loose power you can still steer it and brake (sort of).
WalleyeMikeIII
Yup, GM not what I think of as top tier IT organization…but that’s what we need!
SSGUNNER
Got the OTA update 2 weeks ago for my 2021, got home, parked and went about my day and has been fine no issues.
i'm sure almost all ota updates will go perfectly, but it's that small percentage that have a problem like anything
all it takes is a voltage drop during the process and wammo instant problem
B520044
My OTA update/d yesterday. NO issues and nothing seems to have changed....
Pro299
Ran the OTA last night. First startup this morning was several seconds longer than usual and stumbled before smoothing out. Subsequent starts were a second or two longer than before, but seems to run OK.
dws1977
‘22 Escalade- The OTA update did its thing and then wouldn’t recognize any key fob and every light was on. I had to disconnect the battery for 15 min and then everything was fine. It was like Kathrine fired up the microwave and it forgot it’s name!?!
Thomas Schneider
Yukon, OK
I got the OTA update notification several weeks ago and started the update which looked like all was going well and left the vehicle. I came back later and saw this on the screen:
So I waited a day or so and tried again; same notification. I did this several times now... same-same. So I disconnected the battery for 10 minutes to see if a re-boot would work, no such luck, so it looks like a dealer trip in the future. Anyone else have this happen??
JamesinAbilene
