Gm Brembo upgrade added...sluggish acceleration and much lower mpg.
randeez
south florida
Hi guys! Just came back from dealership. Again, want to thank each and everyone of you for your input with this matter. Great info exchanged. So...trying to find a way to make this short. My visit to dealership was truly an experience. Will keep this as basic as possible and will answer questions whenever I log in. First service advisor drives car and definitely agrees something is wrong. Agreed with the symptoms I mentioned initially. We meet master tech and another adviser who requested to test drive the car. Both returned and said everything feels perfectly fine. I get extremely aggravated. Clearly the clowns have never driven a V8 to justify the way this driving. After arguing back and forth and not settling for my car to go back in the lift for them to just rotate rotor and say everything is OK, another "master tech" who seems to the most experience one at the dealership arrives. He is immediately notified to go on another test drive with me. We both remained quiet for whole test drove (awkward). Immediately after driving a few miles, we return to dealership and he requests that I exit the vehicle with him while he checks Temps. Both front rotors gave a reading within 4 degrees of eachother. Rear passenger rotors-breaks read 145 degrees. Rear drivers reads 210 degreese. Now, with these rear calipers-breaks...they actually contain the ebrake system right on it. It's either the installer jacked it up installing the things or the rear caliper or calipers are defective. He believes the ebrake somehow is somewhat active. The grooves on the rear driver side should have been a clear indication something was wrong but this damn dealership loves playing stupid games. He stated he can unplug the ebrake system and drive car but in uncertain what type of codes or nonsense he will have to reset after doing so. This part is on back order and will be hard to come around. Dealer will do a warranty claim - whatever that is with gm for a replacement. Tech is stating since steering is not swaying towards one direction, both sides may be dragging with one being worst. Will have to compare after new one is installed. The absolute weird thing is that non of us can feel the difference in heat by touch or scent. Only when we repeatedly put temp scanner to it we repeatedly get an avg of 60 degrees difference. No smell, fumes, irrgular hot wheels to the touch...just drastically difference Temboth sides. sides.
thanks for the update
possible the first time you brought it to them they thought upgrade included rear and tore one side down before realizing it? retracted the caliper and then put all the "used" parts back on?
sucks something that should be so simple dealership turned it into a mess
Chad G 1979
You know that both rears are dragging now and is causing the issue. With both dragging to some degree, they don't have to heat up a lot to cause a decent amout of drag. And when checking the temp by feel, were you touching the rotor or the calipers or wheel themselves? You should definitely be able to feel heat even at 145(thats hotter than straight hot water from a water heater is supposed to be). And at 210, you would burn yourself pretty quickly just touching it. They do need to fix the issue.
T
Tahoered
I am surprised they didn't check to make sure it was all ok mechanically before they loaded up the parts canon.
I'm really leaning towards technician error tbh. These dealers are hiring anyone off the streets with limited experience.
T
Tahoered
I was doing it by carefully touching wheels and after a little even sticking fingers quickly for the touch. I guess that was the worst way to check since there was no way my fingers would be able to differentiate between very hot and extremely hot, lol. But hey, that's why I relied on all of you guys for some thoughts. I am grateful.
WalleyeMikeIII
Sunny and Snowy Minnesota
So, did they actually “fix” it??
DuraYuk
Sounds like they have no idea what the problem is. The temp differential is interesting. But a rotor should be getting hot if brakes are constantly dragging. That heat won't go away since it would be constant.
I wouldn't be surprised if their 'fix' doesn't fix it.
Just strange that the rears are messing up after a front brake upgrade.
Looking forward to the update after the 'fix'
WalleyeMikeIII
There is a rear upgrade in this package...only cosmetic, but it is a new caliper, painted red to match the fronts.
DuraYuk
I see. Still in surprised the temps are not blazing hot. It's either dragging or its not. And since its not pulling it would have to be both sides but only showing higher temp on one. If it's not piping hot I think they are on a wild goose chase and the problem is elsewhere.
I've seen binding u joints cause this sort of thing. Labored driving etc.
Interested to see what it ends up being after the 'techs' are done throwing parts at it.
I still don’t think it’s the brakes, they would really have to be dragging hard in order to cause that much of a drop in mpg and performance. And if it was the park brakes, the pads would wear down quickly and not be dragging much after awhile. I’m still leaning towards something electronic.
BC
Seems to me that someone must have touched the rear brakes, maybe I missed something but sounds like fronts were done and then there was an issue and it’s pointing to the rears. Maybe they did a pad slap on the rears and dorked it up. I once accidentally (read dumbass) installed my rear pads wrong, insides on the outside, they were tight when I reinstalled calipers over rotors but didn’t think anything of it, attributed it to the new pads, I immediately knew something was wrong before I got to the end of my street, didn’t feel right and I knew they were dragging just like OP, I returned and they were warm from the short trip. They rotated ok but not nice and free. I messed with the parking brake adjust but that didn’t change and I even replaced a calliper because piston didn’t seem to compress all they way. I finally figured it out because the rivots that hold the pad material to the plates were interfering with the calliper contact point on the outside and with the piston on the inside. I swore at myself a bunch but once I swapped them and put them in the correct way (squealer on the inside pad) (dumbass) calliper slid back on like no one’s business and life was good, no more dragging!! Lesson learned!!
WalleyeMikeIII
All, the GM Brembo Upgrade includes rear calipers as well (they are the same as the Stock calipers, but are painted red to match). I assumed, perhaps wrongly, that the OP said he got the GM Brembo upgrade, that they swapped the rear calipers too. OP said that the folks at the dealer found “something” and they are investigating further. Let’s see what he has to say after they complete the investigation.
Thrust
ICT
You probably need to verify that statement. Need the OP to clarify if they did all 4 locations or just the fronts.
WalleyeMikeIII
You are right; guess the rears are a second accessory…so yes; need op to answer.
BC
Ya for sure, will be great to hear what they find. Seems to me, before the job, all was well and now seems rears are dragging so is why I piped in with my story about my screwup. Like one of the others members commented, you never know who might have done what, sometimes, if a journeyman is doing the fronts, an apprentice or shop hand might have got charged with the rear slap, just spit ballin but is not an unlikely scenario in my experience.
olyelr
Elk Rapids, MI
60 degrees difference is almost a complete moot point.
Ive had brake calipers stick in the past. The last one that i actually measured with my infrared gun was over 700 degrees. And that was on a little minivan in which i honestly couldnt even hardly tell it was sticking as far as driving went…other than the burning hot smell lol.
olyelr
Elk Rapids, MI
Took me a while, but i found a pic for proof…
DuraYuk
My point exactly.
olyelr
Elk Rapids, MI
I’m still wondering about OP’s earlier comment about grooves in left rear rotor.
Yes…that definitely caught my attention too. Obviously should not be any of that this early in the game so something is definitely funky…but a dragging brake is gonna get A LOT hotter than 200 degrees.
Conedaddy
