2003 Yukon General Maintenance
adventurenali92
Big Bear Lake, ca
Bummer on the plow truck! Hopefully you can get it up and running! Nice wheel choice on the Nali!! They look great in contrast to the body color! As far as the coolant issue check the heater core hoses at the firewall as the T connectors tend to get brittle and crack and then they can be susceptible to leakage.
robhotdog
Do the 100k service in your owners manual..I would also replace upstream O2 sensors at this time. USE ONLY OE PARTS!! Catch can is a good idea if you do your own maintenance. They do need to be monitored and emptied!! All they do is keep the intake system cleaner and reduce carbon build up on valves. Refer to owners manual for correct fluid types.
Sam Harris
A little of both. Amazon had some good deals like AC Delco plugs and wires, Summit Racing had the best price(and in stock) the AC Delco water pump..... and there is one in town........ fluids and other parts local chain auto store
Be careful with Amazon and eBay “Delco” parts. Especially spark plugs. These are notorious for having counterfeit plugs. If they are super cheap, avoid them!
W
Wings720
What does this switch do? I thought it was an ignition kill switch but doesn’t appear to be.
03X2
South of Atlanta Ga
Hey Y'all I just picked up an '03 Yukon Denali. I bought it in Burlington,Vermont but luckily its a California car that I saved from certain death by salt. It had 123k when I bought it and its got roughly 126k now. What kind of General Maintenance should I be doing? Tried to search but didn't have much luck. Any insight appreciated. Also any cool mods or tricks would be helpful. Thanks guys.
Looks kool, I like the ‘fire missiles’ and tag in the console. Wish I had some of the tags/pins from my time. Have to find a surplus stor. :)
bayareadude84
Methahoma(temporary)
does the stereo receiver work with the stock bose speakers?
If it says BOSE on the stereo then yes it should work, If not you'll have to purchase/install a bose interface module
Personally I swap out ALL my GM trucks to these 10" tablet touchscreen radios !! It sealed the deal with the family who bought my 09 Silverado lol
Dave
MassHoe04
Western MA
I have Bose in my 04. I just ordered Boss BE7ACP (see list of items in "What I Did on my..." thread). I decided to let Crutchfield figure out what I needed to make Bose and steering controls still work. Then, for $25... They will do all the connections between the new radio plug and the connector that goes to your vehicle harness. Worth not having to look at wires and trying to match up wire colors and making a bunch of connections. Plug the two ends in and 90% of the install is done! I should be getting it this weekend.
Sam Harris
Agree. Crutchfield is great! And those wiring harnesses they make for your install.. :win:
W
Wings720
Did quite a bit of maintenance this past week.
-Fuel pump
-Front and rear diff fluid drain and refill
-oil change
-replaced washer bottle and pumps
-new wipers
-added 2 usb plugs in dash
-New battery.
-remote start
Front diff fluid had quite a bit of metal in it Prbly not good. Think she may be terminal.
I was 2 Qts low on tranny fluid; have a slow drip out of the return lines.
Radiator may be shot lol. Also need to replace one of the T’s on fire wall which is the coolant leak I’ve been chasing.
W
Wings720
W
Wings720
Sooo i made a big list of stuff I wanted to get done. Anyone have anymore suggestions? Also what do about the front diff just keep swapping fluid till it explodes? When I go from Park to drive or drive to reverse it sounds like the t case slams hard. There was minimal metal in fluid. Also does this when you stop accelerating and resume acceleration.
bayareadude84
Clean out your intake with a HARD detergent with PEA
Power steering vac out and replace new fluid
Brake flush
Check your rotors, pads, calipers
Fix your trans leak and replace with new trans filter and fluid
That "STOOPID" T-hose leak is very common have done 4 in last few years on my rigs
Coolant flush ??
W
Wings720
Working on all that this week and a few other issues. Have a weird fluctuating battery gauge I can’t pin down. Just got a remote start think he did some weird stuff. And a mode door actuator
bayareadude84
Thats a bad alternator, Battery, Ground
Happened on my 01 Burb and turned out to be a bad autozone battery !! Luckily still under warranty !!
DolphineasMcGee
VERYYYYYYYYYYYYY GOOD LIST !!!!!!!!! I'm printing this out to remind myself when I pick up these rigs and the cop cars I flip :cheers:
Another recommendation that I do with all my "new" fresh purchase vehicles in my fleet is a good oil flush treatment. Refill with new oil, drive for 500-1000 miles to "flush out" it out and then dropping the oil pan to clean out all the gunk and crap !! And while your at it a new oil pan gasket and o-ring oil pump for the pick up tube that ALWAYS fails and kills your oil PSI and can seriously mess up your engine !!
Napa auto has Berryman's oil change for under $6 !! Its no BG44K but its very good quality product !!
And another VERY VERY important part that pretty much pays for itself is a new fuel filter !!:thumbsup:
Dave
What do you mean by "o-ring oil pump for the pick up tube that ALWAYS fails and kills your oil PSI and can seriously mess up your engine !!"?
adventurenali92
Big Bear Lake, ca
The bottom of the oil pan has a tube that picks up oil to bring it up to the top of the engine from the bottom of the pan. There’s a gasket type ring around the lower half of said pipe, and eventually with age and mileage on the engine it goes bad and doesn’t hold pressure as well. That being said I replaced the pickup tube and accompanying ring, while I was replacing the oil pan gasket and had it all apart. A new pickup tube and ring DID NOT improve my oil pressure. Exactly the same as it was before that whole
Job. It’s just one part in the system and replacing it may or may not improve oil pressure with replacement.
nonickatall
Germany
I would disassemble the calliper and push the pistons back until they are fully pushed back. Then brake until the are pushed out. Be careful not to push them out of the case. Repeat that 5-10 times. That is necessary, because in normal conditions the pistons only move a few millimetres and corrosion or dirt makes the piston stuck over the time.
A good tipp to do that. Remove one brake pad and reinstall the calliper, then you prevent the piston from falling out the calliper case.
W
Wings720
Doing all new front brakes (07 calipers and rotors)
Need to replace hydro boost and master cylinder as well? Any upgrade recommendations?
Also should I mess with the tranny filter and fluid? Or let it be? Been reading these grenade at 160k. I’m at 141k. I repaired the leak from the lines but that’s it so far as tranny stuff goes.
BadDaddy2003
