Kpwweb
- Joined
- Dec 11, 2015
- Posts
- 680
- Reaction score
- 285
The stock Goodyears were past the point of no return and wore the outside edge, even after two alignments. With the onset of rain and snow season, decided to get new tires after 43k.
Went with Mickey Thompson Baja Boss A/T 285/60R20. They are three peak rated and look stunning. They also ride better than the stock Goodyears, both tires at 37psi. A slight hum at speed, but barely noticeable.
I will also say they BARELY FIT. No rubbing, even with bumps and driveway aprons in forward and reverse. Stock wheels with stock offset. I would like to install 1/4-3/8" spacers, but I'm afraid they would rub at that point. The Z71 Tahoe is lifted with EdgyMods links as it has air suspension, probably lifted less than an 1" F + R as much more than that and the ride started suffering greatly with the air bags under more pressure.
Measurements now from ground to fender lip:
38-7/8" to 39" F, 39-1/4" Rear
(got about 3/8" lift from the tires)
