Turning off rear door locks' ability to lock driver doors
navyseal334
2023 suburban - the rear door lock buttons control the entire car (including driver's door) - this would be fine in a car of responsible adults but not wise on GM's part in a car with several young kids who can reach the door lock from their carseat. My 4 year old kid got a good laugh locking mom out of the car at the gas station when she got out to pump gas and left the key in the car.
Does anyone know of a way to limit rear door lock buttons to only unlocking that specific door? I couldn't find anything in the vehicle infotainment settings or the manual... Hopefully I've missed something.
Chad G 1979
If she left the key in the suburban, and the kid locked it from inside, she should be able to press the little silver button on the door handle to unlock the vehicle. All 4 doors have that button that can lock/unlock doors
WalleyeMikeIII
Sunny and Snowy Minnesota
No, actually you can't do that...if the fob is in the vehicle and the lock switch on the inside of the door was pressed, locking all the doors, they all get locked, the security system gets enabled, and unless you unlock from inside, or with another fob, they stay locked. Perhaps ask the dealer, I am sure there must be a way, as it probably is disabled or not available on the PPV versions. Worst case, have the dealer unplug the switch, I am sure it is just a plug in harness.
I think the best you will get is to unplug the switch at that door, the one the kid is touching, not the one down inside where the locking mechanism is.
Chad G 1979
Hmm odd they allow you to lock the vehicle with the fob inside.
WalleyeMikeIII
the fob is not accurate enough for any other use, you could be inside or 10 feet away it doesn't know the difference
Not true, they use multiple antennas and can tell if it is inside our outside. Don’t believe me, sit the fob in the garbage can next to your ride and try to start it…you can’t…bring the fob inside..it will starts.
You can lock a fob inside in case you have another that you want to take with you.
The owners manual tells you that it checks for a reduction in number of fobs inside the vehicle to determine if you can lock with the keyless entry button or fob button.
But hitting the lock button on the door with all doors closed will always let you lock the doors. And this is good design, it’s a safety feature. So you can sit inside the car and lock all the doors if needed.
I figured if anything it might know if it was in the slot, still must be near field detection
navyseal334
navyseal334
It makes sense being able to lock the doors with the key inside (e.g. you're in a rough part of town and someone is approaching your car). Using the outside lock buttons to open the doors while a fob is inside doesn't - otherwise the creep approaching the vehicle would be able to unlock all the doors you just locked.
What seems illogical is giving the ability for the rear passengers' door lock controls to lock/unlock the entire car. Again, this would be fine in a car of responsible adults but with kids in the back, it is predominantly a liability.
WalleyeMikeIII
Unless, again, is a spot where someone wants to get in the car and lock all the doors...for safety. Imagine some criminal is about to assault you, and you jump in the back seat...and want to lock up...if that lock button not there, you are not happy.
I'd say the best "solution" is a remedial one...where it becomes clear to your children the consequences of doing this.
Was your wife able to use the My<Chevrolet/GMC/Cadillac> app to unlock the doors using her phone?
csan2879
