Inner axle shaft fixin
Jobi-Wan Kenobi
Jobi-Wan Kenobi
@gooffeyguy pry bar and a dead blow. Today I was trying bigger pry bars, pry bars wedged in behind wood blocks (since the shaft wasn't in all the way) and had beaten them in to try getting the taper to push shaft out, and wedging a pry bar in and beating the shaft with a dead blow.
St. Louis
I've heard of people using a $6 Felling Wedge from the hardware store to separate the axle stub from the housing.
Jobi-Wan Kenobi
Jobi-Wan Kenobi
Dad and I took by another guy this morning. He didn't have a slide hammer but he had a bearing spreader. We got it apart but we lost the shaft in the process. Looks like new shafts cost almost as much as an entire used axle assembly. I see one of the salvage yards here has a pile of shafts though. I'll check with them to see what they want for one.
Jobi-Wan Kenobi
Jobi-Wan Kenobi
I got the axle assembly mostly put back together yesterday. I took it to my place of work. Spent pretty much the whole day there getting it cleaned up and putting it together. For whatever reason I have one seal that I couldn't get back in (ironically the one for the shaft on the drivers side) so probably deal with that tomorrow.
With this thing out, is there anything else that I should do besides the o-ring for the oil pick up tube before it goes back in?
Jobi-Wan Kenobi
Jobi-Wan Kenobi
@Rocket Man no, my dad and I took it over to a guys place last weekend to see if he could help get it apart after we pulled it and split the case. He had a bearing spreader on there loaded up pretty good but the cir clip wouldn't let go. The flange on the shaft ended up breaking so we ended up torching the flange off and up pretty much disassembling the entire thing. From there the shaft was able to be pushed out with a press.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Damn!!
Jobi-Wan Kenobi
Jobi-Wan Kenobi
Well I'd have rather spent Thanksgiving weekend doing other things besides working on the Tahoe but here we are
Super productive day yesterday. Got the engine oil pan dropped and changed the pickup tube o-ring. Got the pan put back in with a fresh gasket. Dad helped me get the axle assembly back up there then got most of the front end back together.
This morning finished getting things back together and took a torque wrench to a few things. Got the engine and axle filled with oil and went for a drive. Things seem good. Now on to other things.
89Suburban
SE PA
Good job man!!!!
enigmaspeed27
