RLC2020
- Joined
- Oct 6, 2021
- Posts
- 66
- Reaction score
- 65
Just had my lifters and pushrods swapped out after having the #7 lifter fail on my 2015 Yukon with the 5.3L and 67k miles on it. After getting the truck back the mechanic informed me that the idle was rough and he found 2 injectors that aren't "balanced" and that there is a tsb and I should have the dealer sort it out for me. I'm getting a P2099 code for fuel system too rich and the idle bogs down to about 350 rpm when idle in gear. runs fine when on the throttle.
I'm only finding a tsb for 2016-2017 models, is my 2015 covered by something here? Also, should I replace with OEM or is there an aftermarket solution that makes more sense to use?
TYIA.
TYIA.
